Re: what kind is this pad
Originally Posted by mudcat
Is it for buffing out wax or applying polish?
A wool pad is for heavy correction and compounding, I wouldn't recommend using it to buff off wax.
That is a double sided wool pad, you need an adapter to use it on a rotary buffer.
Just to be clear, is the reason for needing the adapter because the threaded spindle on the rotary is too long? Looks like the adapter is shorter, so that the spindle does not reach through the pad and potentially cause serious damage to the working surface. Is this correct? I've never used a double sided pad and adapter.
Yes. And, because it's a double sided pad, the pad on the buffer side will be too close to the body of the buffer.
Yes.
You can use and test out double sided pads and all the rotary buffers at our Advanced Class...
Sign-up for our next Hand-On Detailing Classes!
Detailing 101 Class - Machine Polishing - Saturday, May 14th, 2011
Detailing 102 - Wetsanding, Cutting and Buffing for a Show Car Finish - Sunday May 15th, 2011
Or call 1-800-869-3011 to sign-up over the phone
Note: You must have attended Detailing 101 before you can take Detailing 102
Hands-on Classes with Mike Phillips
Info Threads - Post Questions or Comments:
Detailing 101
Detailing 102
Live Broadcast
By signing up for a class you agree to sign a Video Release Form upon arriving to the classroom for the possibility that these classes will be streamed live over the Internet and/or recorded for later use. See you here!
By Mike McDonald in forum Off-Topic
Last Post: 10-27-2013, 09:18 PM
By Kacz in forum Introduce Yourself
Last Post: 08-12-2013, 07:46 PM
By jgibson2980 in forum Off-Topic
Last Post: 06-09-2013, 05:15 PM
By andym in forum Auto Detailing 101
Last Post: 06-24-2011, 10:39 AM
By Meghan in forum Off-Topic
Last Post: 06-18-2008, 11:40 PM
