Sonax Profiline Perfect Finish...
Such a little curiosity.
The doors I did (cutting) with Meguiar's DA Microfiber Correction System - D300, MF cutting pad, DAS-6 PRO.
And now a small comparison of finish.
The right side is Meguiar's Finishing Wax (D301) on MF finishing pad and DAS-6 PRO after 5 months and only two very delicate, cautious washes.
The left side is Sonax Profiline Perfect Finish on HexLogic white pad and Flex PE14-2-150 (rotary).
It's 12 years old Opel Astra Coupe Bertone with normal or light hard paint.
Opel Astra Coupe Bertone - Second Youth
Best regards
Piotr Boguslawski
Re: Sonax Profiline Perfect Finish...
That's exactly what I would expect to see.
OAN:
...normal or light hard paint.
I like the descriptive terms that you use over yonder.
VT
Originally Posted by glen e
And I find the Sonax polishes extremely easy to remove and have hence, become my "go to" product line. A picture is worth a thousand words.
I would lend results to polishing oils and polymers rather than to abrasives, or lack thereof.
And yourself, please?
VT
I wonder if the new Megs d302 would finish that right side a little closer to the clarity of the Sonax (see Mike's new thread regarding the Megs MF system).
2016 Accord EXL V6 w/Navi & Sensing - Black/Ivory
2019 Acura RDX A-Spec - Black/Red; 2019 Acura TLX Base 2.4L - MSM/Black
2008 CRV EX - Black/Black 2003 Accord EX V6 - Black/Tan
The OP used direct drive/foam with the Sonax.
I expected to see the haze with the DA worked 300/MF on everyday hard paint.
Here's the kicker in my book. Foam on direct drive gives a better finish than MF on DA when using the same product in most instances ~ even when results are hidden by the oils/polymers.
I need to go back and read the thread to see if the OP had any conclusions or preferences.
VT
I wiped down the panel twice (or even more) with CarPro Eraser, lots of it. I think that all oils have been washed away.
Best regards
Piotr Boguslawski
use an IPA mixture to wipe it down a few times. Then look at it and that will be your true clean paint with no oils.
Eraser is better than IPA...
Best regards
Piotr Boguslawski
What's the focus of this thread?
I apologize for my confusion.
Thanks.
VT
By L Gunnar D in forum Wet-Sanding, Cutting & Buffing
Last Post: 06-03-2018, 08:55 AM
Last Post: 02-05-2018, 05:37 PM
By zmcgovern45 in forum Auto Detailing 101
Last Post: 08-09-2014, 12:53 PM
Last Post: 05-26-2014, 01:19 AM
By Mike Phillips in forum New Car Care Products
Last Post: 06-22-2012, 08:03 AM
