Swirls and Marks after wet-sanding car
Hello everyone!!
My dark British racing green Jaguar was stripped to bare metal, repainted and send of for wet-sanding. The day after picking up the car from the detail shop where the car was wet-sanded, I noticed that A) the wet-sanding must have been really light because I can see some orange peel type reflections from some angles and what's worse B) the car was full of buffer holograms and swirls......I took it back and the detailers answer to the problem was to use wax !!! ...,went back home, got my Porter Cable XP out, used a orange pad with Wolfgang swirl remover and followed it with some Zymol carbon and that helped with some of the most glairing and obnoxious swirls, but not all.
My questions are:
1-Should I have the car wet sanded again?........since I lost all confidence in the detailer, I even thought he never had sanded the car at all and had just grinded the orange peel of with his buffer and kept the 1.5k , but I can see some sanding marks here and there....
2-what else can I use with my PC XP to remove more swirls?
(And no I am not going back to this guy to fix his mess. If he thinks its ok to return a car with holograms and then covering it up with wax, I don't want him near my car)
Any help will be greatly appreciated
Re: Swirls and Marks after wet-sanding car
From my basic knowledge of wet sanding and compounding via rotary and da (both pc and gg6), I believe if you are still having problems with an orange pad and wg swirl remover, you might want to step it up with a wg compound or meguiars m105, more aggressive compound same pad, that should help the swirls. Speaking about wet sanding, I would use nothing lower than 1200 grit safely, since I don't know the conditions of the clear coat until you level out the clear coat.
Wet sand first, accomplish the results you want from the clear coat and begin compounding to clear up the sanding and bring back the luster.
Originally Posted by spikepaga
My questions are:
I would say "no".
Do you know how much paint the painter sprayed? As in how many coats? Thicker is better if you're going to wetsand. Keep in mind, sanding, compounding, polising and even final polishing all remove a little paint.
If you can still see orange peel you're probably okay as this is a sign they didn't get the paint flat and thus didn't remove too much paint.
If you're going to have someone re-sand though, find out what they use and what their approach is.
THe most aggressive product I know of that works well with a orbital polisher like the PC is the new Meguiar's M101 Foam Cut Compound. This with either a microfiber pad or a foam cutting pad should remove the swirls.
How difficult it is to reove swirls depends upon,
- Paint hardness
- Depth of swirls
How deep the swirls are depends upon,
- What type of abrasive technology was used in the compound
- How hard the caveman detailer pushed down on the rotary buffer while compounding
Did you see any tracers?
Tracers Tracers - RIDS - Pigtails - Cobweb Swirls - Rotary Buffer Swirls - Holograms - Water Spots - Bird Drooping Etchings - Micro-Marring
Today I'll be wrapping up a complete wetsand, cut and buff that we shot a time-lapse video of, it will be uploaded to YouTube after it's completed. It shows the complete process to correctly sand and buff a new paint job for a swirl-free finish wihtout any sign of sanding marks.
Time-Lapse Video: Wetsand, Cut and Buff 1964 Malibu
Throughout this video I show the complete process also...
Video: Helping in the Heartland - Part 1 The Transformation
Well, I can only see the orange peel at angles, where before it was really obvious. I would like the same reflection I get when I am staring directly at a panel when I am looking at in from an angle
Thanks for this, it's always good to have, specially considering both the XJS in question and my E type are both British Racing Green and show swirls if you just look at them
How hard the caveman detailer pushed down on the rotary buffer while compounding..... Did you see any tracers?
Yes. All over. Also, I do know that the painter put extra coats if clear since he knew I was going to wet-sand the car .
The next step is up to you...
Remove more orange peel or remove the swirls from the last guy that worked on your car's paint.
Finding people that are up to date with the best and newest tools for wetsanding locally can be a little hard unless they hang out on forums like this one where it's talked about and the tools are shared.
Mike thanks for your help.
I found a detail shop that does much higher end cars than mine like Rolls and Lambos.
He measured my paint and one panel said "800" on the high end, and the lowest said "230" . He said as long as it does not go below "100" it can be sanded, and he can safely do it again.
Does this all sound right?
I do all my readings in mils, that's how I started out and it's kind of stayed with me over the years...
Using a unit converter I get,
230 microns = 9.0 mils
800 microns = 31 mils
And according to these measurements I would agree it's probably safe to re-sand.
I'm very careful about wetsanding and compounding other people's paint and I'd rather error on the side of caution than make a mistake. For this reason I like to machine sand over hand sanding wherever I can and I do tend to tape off any edge or raised body line at least for the sanding and compounding step.
If you look real closely at any show car that's been sanded flat you can usually see the orange peel show up as you get closer to a raised body line or edge.
It's not that the paint cannot be sanded right up to the raised body line or edge as it certainly can, it just takes more t-i-m-e to sand, compound and polish close to edges and time costs money. (your money )
If you look at this picture of the car I have out in the studio right now, you'll see I've used 3M Blue Vinyl tape to cover all the edges and raised body lines.
This is called being careful with other people's paint jobs...
I'll have to leave it up to you as to whether or not to let this other company give your car a second try, it sounds like they know what they're doing.
I use both 3M and Meguiar's sanding discs for machine sanding and for the above project I'm finishing out at #5000 grit and then compounding with Meguiar's M100, followed by M205, followed by Pinnacle Advanced Finishing Polish followed by Pinnacle Souveran Paste Wax. (The paint is over 30 days air cure).
The color red pixelates on computer monitors, (at least my monitors), but I think you see what I mean...
One thing for sure, wetsanding and then all the steps that follow it are a lot of work and take time to do right. But when done right the results are worth it for the right cars.
Mike, your help has been tremendous. The car is getting redone, just the upper half of the sides from the crease up:
So basically the upper 1/2 of both sides. While I am scared that the clear will be thinned out too much, I do think these guys know what they are doing, so hopefully I won't be back here complaining that my clear burned of any time soon
Thanks
Well here I am, 2 times wet-sanded, lots of $ later still unhappy. Either they where super generous with the clear at the painters or something else is wrong
If it were me I would be getting some some money back from both detail shops. Where are you located?
What are you not satisfied with this time around?
Sent from my SAMSUNG-SGH-I897 using AG Online
By Deranged_9n3 in forum Show N' Shine
Last Post: 04-06-2016, 05:55 PM
Last Post: 05-29-2014, 07:48 AM
By SuperGlide in forum Off-Topic
Last Post: 08-25-2011, 10:04 PM
By kovalchuk71 in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 03-15-2009, 03:43 PM
By kellyinkc in forum Auto Detailing 101
Last Post: 07-16-2006, 01:00 PM
