Re: Wet-sanded through OEM clearcoat
Ok, so the vehicle is back from the airport and had a chance to snap some pictures. I've identified something I noticed using black tick marks. The change in shade during the sanding process was the first clue I went to far. Now I'm waiting for my bottle/brush and aeresol-type clear coat. I think the base coat looks good from the pic I took in the sun. Should I let the body shop take over at this point or move forward with the clear???
Would the body shop charge you more if you tried it yourself and the results weren't very good? I can't imagine why they would as their job would be the same.
They shouldn't. They're gonna have to sand and clear either way. Really, he's got nothing to lose.
New on AG. Don't want to bust your bubble, but from what I can see on the first pic, is the clear is way to gone. It's true , to do it right the whole panel should be cleared. If attempting to blend, try rolling back your tape edges and only blowing a little clear into the rolled edge. Also,on a blend of clear, you can wipe down the area beyond what you are blending to help soften the clear a little, to make it less noticeable. Go 2-3 inches pass, using base and clear reducer. Good luck.
Can you explain further? I'm not getting what you mean....
I'm a newb at this - not getting what you mean....can you explain?
Rolling tape or back taping means, having the tape already on your paper - I have a paper machine that puts the tape right on the paper- or put tape on edge of newspaper, you won't be laying that much clear to worry about having auto body-paper, put the tape edge where you want to end your seam and fold the paper back. You will then have a 180 degree rounded curve in your tape , as you spray the clear lightly up to your taped edge it will blow back an lighten the edge so you won't have a tape line. Hope this makes sense. With reference to wetting the edge, take reducer, base coat and clear coat reducer is the same, if you wipe your edge with it , it will help soften the clear just enough to also make the blend less noticeable. This is safe on cured clear. Hope I explained this a little better. As I said before , it's not the way to do a proper repair, but it should make it a lot less noticeable. Good luck. Let me know if you have any other questions.
Last Post: 01-04-2016, 01:43 PM
By rockford33 in forum Auto Detailing 101
Last Post: 12-13-2015, 04:13 PM
By Agribuff in forum Auto Detailing 101
Last Post: 04-23-2015, 01:47 PM
Last Post: 09-12-2013, 06:15 AM
By robollama in forum Auto Detailing 101
Last Post: 09-13-2011, 08:13 PM
