Results 11 to 20 of 25
    Super Member DetailKitty's Avatar
    Jul 2013
    PA
    5,026
    Re: clear coat burn from scratchx use?
    I'm guessing it just needs some polishing on the area you scuffed up.
    2022 Jeep Gladiator Rubicon • 2021 Ford Ranger Lariat •2016 Alfa Romeo 4C Spider • 2006 Buell Lightning-Bolt • 2004 Jeep Wrangler Rubicon
    Jun 2016
    But do I risk applying some pressure when polishing the spot again?
  3. #13
    Nov 2015
    Arizona
    1,419
    My guess is hazing from the mf applicator. In my experience, It's so easy to micro-mar or haze with microfiber by hand when doing focused abraiding. I'd try some polish on a foam applicator, making sure to apply even pressure across the pad. Maybe even pick up a hand-applicator backing plate (or whatever those are called).
  4. #14
    Super Member David Hayward's Avatar
    May 2014
    Mentor Ohio
    655
    Quote Originally Posted by Dave59556 View Post
    In my opinion the damage is already done if the clear isn't just hazed or marred. If you have compromised it from the scratch x then it's too late and can't hurt trying to go harder with the polish. The spot may increase in size if the clear is thinning out in the area though.
  5. #15
    Super Member RaskyR1's Avatar
    Apr 2008
    Shakopee, MN
    3,733
    Looks like a strike through and the scratch looked a little deep too. Was the bumper ever repainted before?
    Quote Originally Posted by CieraSL View Post
    http://Raskysautodetailing.com/
  6. #16
    Apr 2008
    Shakopee, MN
    3,733
    Where you rubbing the SrcatchX left to right (horizontally)?
  7. #17
    Jun 2016
    Brand new car only a month old. Yes I started in circles, but then rubbed some horizontally. Looks like I'll have to have it repainted then...
  8. #18
    Oct 2009
    493
    You are committed at this point, try polishing it out by hand.
    The best way to do work by hand it with your palm and not using finger pressure. Dont be afraid to do a light application of ultimate compound with a MF applicator. Just take it slow, use enough pressure to create a bit of friction and stop after 30 seconds or so and inspect.
  9. #19
    Jan 2015
    Dahlonega, Ga (North Georgia)
    94
    It does look like you burned through the clear. I had a black Nissan that was burned through in an area the dealership tried to "spot fix." It looked identical to your photo. The dealership paid for a re-paint....
  10. #20
    Jun 2014
    Chandler, AZ
    3,360
    My suggestion would to go over the spot with some Megs #7 followed by Megs #26.
    Hard to burn clear with scratch-x, but one must take three factors into consideration
    1.) This is a Honda and Honda's have soft paint
    2.) Honda's apply very few microns of paint (average 80-90 microns)
    3.) This was on a plastic bumper cover which cannot disperse heat like sheet metal can.
    Follow the above suggestions, #7 & then #26. Odds these two applications will diminish the unsightliness and or remedy the situation.
  1. Is this clear coat burn or not
    By estcstm3 in forum Auto Detailing 101
    Last Post: 04-13-2018, 09:12 PM
  2. Would clear coat burn be obvious?
    By jdgamble in forum Auto Detailing 101
    Last Post: 08-03-2017, 01:47 PM
  3. Possible clear coat burn
    By BennyHFP in forum Auto Detailing 101
    Last Post: 06-17-2014, 12:24 PM
  4. Did I burn through my clear coat?
    By Skimmer0220 in forum Off-Topic
    Last Post: 12-18-2013, 02:20 PM
  5. Can you burn through clear coat with a PCXP?
    By moparfan1986 in forum Auto Detailing 101
    Last Post: 12-15-2010, 12:55 PM
