car wax, car care and auto detailing forumAutogeekonline autogeekonline car wax, car care and auto detailing forum HomeForumBlogAutogeek.net StoreCars WallpaperLink To UsvBGarageGalleryDetailing How ToFollow us onTwitterFacebook
Go Back   Auto Geek Online Auto Detailing Forum > Detailer's Library > Tricks, Tips and Techniques
» Official Detail Fest 2010 Information Thread!!
» Current Poll
How do you prefer your information?
Paper Handbook - 23.53%
28 Votes
DVD - 12.61%
15 Votes
Digital PDF Download - 63.87%
76 Votes
Total Votes: 119
You may not vote on this poll.
Reply
Thread Tools Display Modes
Old 01-05-2008, 03:01 PM   #11
Re: Menzerna Polishes- Methodology Part II
Jon, I am looking forward to the book. Thank you once again!
ZoranC is offline
Old 01-07-2008, 02:25 AM   #12
BANNED
TOGWT's Avatar
Thank you all for your confidence in me by making this a 'sticky'.
Be aware that I don’t manufacture, sell or have any vested interest in any of the products mentioned; other manufacturers products may work equally well. I have tested the products mentioned and have found that they will perform the task more than adequately using the methodology and tools cited.
TOGWT is offline
Old 01-07-2008, 05:21 AM   #13
BANNED
TOGWT's Avatar
Quote:
Originally Posted by maesal View Post
Thank you again Jon.
I only see 105FF in your posts. Is it right or is it a mistake and you're talking about 106FF?
4. Nano Polish (106FF) Finishing 22865 - will remove 2500 grit, for light surface marring and / or surface finishing, cut 2.5 - gloss 5.0 for LSP ready use a primed White (softer less dense foam (70 PPI) with a light abrasive cutting action )LC CCS foam pad - 1100 RPM
5. Final Finish Polish (PO105FA) the up-rated version of P0106FF, this polish is formulated with very finely milled micro abrasives so they don’t require much to ‘breakdown’ and won’t cause surface marring. It
will remove 2500 - 3000 grit, for surface finishing, cut: 2.5 – gloss 5.0 contains very finely milled micro diminishing abrasives that have a sharp edge that can cut ceramic clear coats as well as the more conventional clear coats, for LSP ready use a primed White (softer less dense foam (70 PPI) with a light abrasive cutting action) LC CCS foam pad, 1100 RPM.
TOGWT is offline
Old 01-07-2008, 05:53 AM   #14
maesal's Avatar
I'm a bit puzzled Jon, I used in the past Final Finish 106FF and nowadays I use a lot 106FA, but never heard about any 105XX.
Here the product info in the Menzerna web. It doesn't appear 106FF because it is outdated, it just appears the 106FA.
maesal is offline
Old 01-07-2008, 07:01 AM   #15
BANNED
TOGWT's Avatar
You are correct 106FF > 106FA- corrections made
TOGWT is offline
Old 01-07-2008, 07:52 AM   #16
maesal's Avatar
Ok Jon. Thanks again.
I'm a bit curious about why do you always recommend the white CCS pad with the 106FA or FF. Maybe is your way of showing an example of use, I don't know.
maesal is offline
Old 01-07-2008, 09:11 AM   #17
BANNED
TOGWT's Avatar
These polishes are foam pad ‘dependant’ as far as its paint correction / renovation abilities are concerned (i.e. use a polishing foam followed by a finishing foam pad) It is not de rigueur to use a cutting pad first but it’s difficult to judge what finish correction is required. Diagnosis is the key; not guesswork; always use the least abrasive product / foam pad combination before ‘stepping-up’ to something more aggressive.
TOGWT is offline
Old 01-07-2008, 10:33 AM   #18
maesal's Avatar
Yes, I agree, but I prefer using other polishing pads, I don't like the CCS. For example yesterday I compared using a black polishing pad from 3M and a white CCS polishing pad and the one from 3M performed better imho. But it will be people who prefer the CCS pads, sure.
maesal is offline
Old 01-08-2008, 02:26 AM   #19
BANNED
TOGWT's Avatar
Lake County Mfg CCS foam pads are what I use / prefer; so I use them as a benchmark (thats the reason behind so much info i.e. colour, PPI, foam composition, etc) so that would enable anyone to select an equivalent foam by another mfg.
Let me know if you have any questions, I’m only too glad to share knowledge / experience
TOGWT is offline
Old 01-08-2008, 02:35 AM   #20
maesal's Avatar
And you do it very well my friend, thanks for so many advices
maesal is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Menzerna Polishes - Methodology Part I TOGWT Tricks, Tips and Techniques 34 04-27-2009 01:09 PM
Menzerna Polishing Cream Metal Polish Meghan New Car Care Products 3 12-06-2007 05:10 PM
Another Menzerna by request! Meghan New Car Care Products 29 10-12-2007 04:13 AM
Menzerna Polishes --- Instock killrwheels@autogeek Auto Detailing 101 33 05-30-2007 08:46 AM
» March 2010
28 1 2 3 4 5 6
28 29 30 31 123
» Car Care Brands
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
