Detailed Detail: '03 Lamborghini Murcielago **Picture Heavy**
Happy New Year Geeks!!
It's hard to believe how quickly time passes! 2 years have come and gone since I've posted a thorough detail write-up, so I am beyond overdue for some material! I'm really going to make it a point to catch up and share a few projects here and there, so stay tuned for future posts. Anyway, let's get to it...
Year - 2003
Make - Lamborghini
Model - Murcielago
Color - Giallo Orion
Well, I've been patiently waiting nearly 3 years to get my hands on this monster, so when the call came in I was more than ready. This car is no doubt special in many ways, but for me I am in love with the paint and couldn't wait to see how it would turn out. The color shift from multiple pearls and yellow paint color really jumps out and is something that must be seen in person to really appreciate. Very difficult to describe in words. Depending on the angle and light, it can have a green hue and shift from different shades of Gold, Yellow, and Orange. The good thing about this paint is that it really does a great job at hiding defects in all lighting conditions, but to the trained eye it definitely needed some TLC. It had plenty of room for improvement and I knew I had some serious work ahead of me! I was told to do whatever it takes to make the paint look the way it should. Especially on a car of this caliber, why not have it looking it's best? Roughly 25 hours went into correction alone and it really paid off. Main focus and energy was put toward the paint, however the engine and interior would be getting a basic detail as well. In addition to the restoration work, the old yellow and dull Paint Protection Film would also be removed and replaced with fresh film to compliment the freshly restored paint. The end result was nothing short of spectacular and I hope you all enjoy the time spent on putting this write-up together.
A few photos showing condition upon arrival before sundown:
Tire dressing had become a little grimey and brown... Soon to be stripped and replaced with a clean matte finish
Wheels and calipers covered in brake dust, giving the Matte Black wheels more of a Matte Brown look
Barrels had an extra thick layer of dust
Very difficult to capture defects in the finish with such an intense paint color and pearl effect
Piano Black trim had quite a few deep scratches and quite dull
Tails needed some refinishing as well
Unfortunately we had some water spot etchings from PPF removal in both the trim and paint
This picture shows the unfortunate reality of having "custom" cut PPF installed on your vehicle... After it's removed, you will (more than likely) be left with deep razor cuts that cannot be corrected
Tips needed a little work
Interior glass needed a good cleaning as it was very difficult to see through. Rest of the interior received an all around thorough cleanup from accumulated dust and dirt. Nothing too special went into this area as we will be revisiting the leather for rejuvenation in the spring time
Not filthy, but definitely in need of a clean-up
-DiamondDetail
Re: Detailed Detail: '03 Lamborghini Murcielago **Picture Heavy**
Cont'd...
Onto Prep:
Special care taken to not allow excess water "forced" into areas we don't want... Engine will be delicately steamed and wiped down later in the detail
Badges, seams, and tons of honeycomb grille brushed out prior to full wash
Vehicle was then rinsed, foamed, and hand washed using the 2-Bucket Method. Wheels and wells were not washed being that the vehicle would be leaving for PPF install after front-end was corrected and then return for final correction etc.
All cleaned up and ready for Decontamination
Clar Bar - Before. Surface felt gritty and I knew some heavy contamination would be lifted.
After... Sure enough, Clay Bar shows quite a lot of contaminates picked up off the paint surface on just the Frunk (front trunk lid/boot lid, whichever you prefer) and front fenders. The original owner may have clayed the car prior to my client taking ownership, but I know for a fact it hasn't seen clay in over 8 years.
Paint Correction:
Now that we have a contaminate-free surface, we're able to dial in a test-spot and determine a plan of attack for the rest of the project.
...But first, out came the thickness gauge to give us some insight as to how much paint we're working with! Being that the Big Boy Lambo's are hand-painted, I expected to see some good thickness, and the gauge helped to confirm that. With that said, although we had plenty of paint to work with, paint preservation is always kept in mind and constant readings were taken throughout the process of correction on each panel. This is time consuming, but no shortcuts are taken. Period.
Deep scratches on the Bat Wings. Again, very hard to capture on camera
After
Before
After
**NOTE** These photos are after the 1st Step of Correction only! Two additional polishing steps would follow to remove any/all micro-marring and produce the highest gloss possible.**
After the Test Spot was dialed in, it was time to move onto the front-end. Additional time was spent safely removing leftover adhesive residue from PPF removal before correction.
Deep scratches and marring from PPF removal and existing defects
After
Frunk lid completely corrected
Front fenders Before/After
Holograms among other defects from a previous "Buff Job" rediscovered after film removed
Handled
Fender Details
After
After Front-end, Doors, and Skirts were all corrected and polished up to near perfection (only a handful of deep scratches remain), it was time to head over to get some fresh film applied. Pulled out in the sun to try and capture the incredible effect of this special paint before delivery. I was in disbelief seeing this in the sun for the first time after being polished. It was absolutely stunning and I couldn't wait to get my hands back on her!
Close-up Sun shots don't lie!
-DiamondDetail
Great work! That metallic flake really pops now.
Awesome detail on an awesome car!
Scott Harle
Autodermatology
#autodermatology
Great work. Very cool of the owner to let you drive it.
Finishing Touch Auto (Stayton, OR)
Ryan Hendricks (Owner) 503-602-8483
FTA Website
By Oakes in forum Show N' Shine
Last Post: 06-13-2016, 09:01 AM
By Deranged_9n3 in forum Show N' Shine
Last Post: 02-03-2014, 02:26 PM
By Petrucci_M3 in forum Show N' Shine
Last Post: 12-12-2009, 10:59 PM
By blk45 in forum Show N' Shine
Last Post: 02-23-2009, 09:03 PM
By conan777 in forum Show N' Shine
Last Post: 07-16-2008, 02:37 PM
