Page 1 of 2 12 LastLast
Results 1 to 10 of 15
    Super Member lawrenceSA's Avatar
    Feb 2012
    Durban - South Africa
    1,713
    Space Grey BMW 320d - Detailed by Lawrence
    I detailed this car back in the beginning of December for an existing client of mine who was unfortunately subjected to some ongoing road maintenance right by his house, resulting in a car a lot dirtier than he would normally have it, and one with a lot of tar deposits all of the paint and wheels.
    As always the engine bay was tackled first as this is often one of the dirtiest parts of the vehicle and if washed after the rest of the car had been done, you would inevitable 'splash' some of this dirt back on to your clean paint, necessitating yet another wash and increasing the possibility of instilling fine scratches.
    This is what it looked like prior to starting.
    After carefully covering any exposed electrical bits, Carchem APC @1:5 was liberally sprayed over the entire bay via a Gloria Foam Master foam sprayer, left to dwell and then agitated using various Wheel Woolies, Speedmaster and Autofinesse brushes before being pressure rinsed. Autofinesse Dressel was then used to dress the plastics and the painted surfaces were cleaned/polished/protected using Autofinesse Tripple.
    I planned on snapping some after pics once I was completely finished with the car, but the bad weather rolled in and I never landed up taking the car out the garage once completed, meaning I never got any after pics - sorry.
    In keeping with the principal of working from dirty to clean, the wheels, tyres, brake calipers and fender wells were tackled next.
    APC was applied
    And left to dwell before being agitated in order to remove the bulk of the surface dirt - in my opinion, it is wasteful to spray an iron removal product directly onto wheels with this loose dirt / brake dust as the iron remover has to first make its way through this dirt before it can start tackling the embedded iron particles - and then pressure rinsed off.
    Carchem Revolt was applied and left to dwell before being agitated with Wheel Woolies - I had to repeat this step due to the stubborn embedded brake dust.
    The wheels were then pressure rinsed (from the top down) to ensure none of the residual iron remover is splashed over the paint
    During the final rinse of the car, the wheels were hit with Gyeon WetCoat and the tyres would later be dressed using Carchem Tyre Gel
    Then it was time to tackle the dirty car.
    The first step was to use the pressure washer to blast off as much of the loose dirt as possible - any dirt removed prior to making contact with the paint will help reduce the possibility of swirls in the paint. This was then followed by a thorough foaming using Turtlewax Hyperfoam
    This was followed by a through soaking in Valet Pro Citrus Prewash which was then pressure rinsed off, and then a 2 bucket wash using Carchem Luxury Shampoo and multiple lambswool wash mitts. Carchem Revolt and Valet Pro Citrus Tar Remover were then used for the chemical decontamination of the paint and this was followed with a mechanical decontamination using Shield Heavy Duty clay with ONR as lube.
    The car was pulled into the garage where the paint thickness was measured and the paint thoroughly inspected. Various test spots were conducted and 1 step using Menzerna FG400 on Orange Lake Country Hybrid Pads was selected - the soft B-pillars and tail lights got an initial cut with Menzerna PF2300 on White Lake Country Hybrid pads, followed by Menzerna SF4000 on Black Lake Country Hybrid pads
    Here are a few before/after shots of the correction process
    The paint was then protected using Dodo Juice Iron Gloss Sealant topped with Dodo Juice Purple Haze.
    The exhaust tip was cleaned using Carchem APC @ 1:5 then polished using Mothers Mag and Aluminum Polish on a Mothers Power Cone attached to a variable speed drill.
    The rest of the details were then taken care of
    Exterior plastics
    Equipment - Foam applicators, MF towels, Q-tips
    Clean - Shield Heavy Duty Vinyl and Rubber Cleaner
    Protect - 303 Aerospace Protectant
    Glass
    Clean - Autoglym Fast Glass, MF towels, Wynns C-Thru
    Badges & Emblems
    Equipment - Q-tips, MF towels
    Clean/polish/protect - Autofinesse Tripple
    Interior Plastics
    Equipment- Foam applicators, MF towels, Q-tips, Various brushes
    Clean - Carchem APC @ 1:20
    Protect - Optimum Optiseal
    Interior Carpets
    Equipment- Brushes, Flex VL35C Vacuum
    Leather Surfaces
    Equipment- Foam applicators, Flex VL35C Vacuum, MF towels, Brushes
    Clean - Carchem APC @ 1:20, various brushes, MF towels
    Protect - Collinite 855
    Finally a few pictures of the car (still stuck in the garage due to the poor weather) - not the best 'after' pics, but they will have to do.
    BMW orange peel is horrendous
    As always, thanks for looking and any questions or comments are welcome.
    Total time spent = 29 hours :hi:
    Sep 2015
    6,281
    Re: Space Grey BMW 320d - Detailed by Lawrence
    Very nice job and process thanks for sharing.
    Feb 2012
    1,713
    Quote Originally Posted by GSKR View Post
    Thank you very much!
    Super Member Paul A.'s Avatar
    Dec 2007
    Tampa Florida
    5,274
    29 hours well spent! Nice work.
    Super Member Bill1234's Avatar
    Apr 2012
    New York, NY
    2,647
    Totally agree with an iron remover product. I always clean wheels first and kinda blow dry them before applying any iron remover. Paint is a different story I guess.
    Super Member fly07sti's Avatar
    Sep 2013
    SF Bay Area, Cali
    2,939
    Great work as usual. Always enjoy reading your threads.
    Super Member FrankS's Avatar
    Jul 2013
    West Palm Beach, FL
    1,560
    Outstanding work as usual Lawrence!
    Great pictures!
    Super Member Sicoupe's Avatar
    Mar 2013
    Oklahoma
    3,352
    Beautiful work as always Lawrence! Glad to see you posting my friend
    Kyle
    Aug 2015
    Andover, MN
    1,729
    Quote Originally Posted by lawrenceSA View Post
    This made me laugh out loud. I work at an independant BMW shop where we see mainly 2005-2014's, and frequently when I'm doing a Pre Purchase Inspection I end up going back and forth - has it had paintwork, or is the factory paint really just like that? Especially paired with minor imperfections (small high spots that look like dirt in the paint, etc), it can make it tough. We make it clear we're no bodyshop, so we don't go as far as hitting them with a paint gauge. Mainly we just look to educate if it's had work and to what extent.
    Thanks for the write up - The car looks fantastic! I really do love to see them taken care of like that, and wish more of our customers cared about their cars. I'd say it's maybe a car or two a month where it seems like the owner actually cares...
  10. #10
    Super Member AZ Mike's Avatar
    Jan 2014
    Phoenix, Arizona
    1,128
    Beautiful work. I enjoy reading your posts as you include the steps and products used. I am always interested in the time taken as well. Thank you for sharing and keep the posts coming.
    AZ Mike aka "Repeat"
  1. Nardo Grey Audi RS3 - Detailed by Lawrence
    By lawrenceSA in forum Show N' Shine
    Last Post: 10-21-2018, 10:50 PM
  2. Monsoon Grey Audi SQ5 - Detailed by Lawrence
    Last Post: 07-24-2016, 06:06 PM
  3. Daytona Grey Audi RS3 - Detailed (again) by Lawrence
    Last Post: 03-27-2014, 01:17 AM
  4. Daytona Grey Audi RS3 - Detailed by Lawrence
    Last Post: 10-01-2013, 02:47 AM
  5. E46 Silver Grey BMW M3 - Detailed by Lawrence
    Last Post: 06-12-2013, 01:23 AM
