Most versatile backing plate / pad size for PC 7336?
I have a PC 7336 I have been using for years. Looking to really improve my skills on the detailing of my personal cars. I am an ex body/paint guy but have continued through the years performing side jobs. More for the love of it than the money, to a fault. Anyway. I have been reading as much as I could here on AGO as well as a few other detailing oriented boards. Through this I see the PC 7336 is pretty versatile in this area. I have a Makita 9227C rotary I purchased a few weeks back now. Not an expert with a rotary but am comfortable and do enjoy working with one. Previously has a pneumatic unit but it failed so I went with the Makita after much research. Very happy I chose it.
For the Makita I have a Meguiars W65 backing plate with a set of W7000, 8000 and 9000 foam pads. Also have the Megs W5000 double sided wool pad for it. I had planned to get the W65DA backing plate and use these pads on the 7336 but see they are often described as too large a diameter for the PC to work effectively.
So I ask you all for the experts opinion on what is the most versatile size BP & pad diameter for the 7336?
Re: Most versatile backing plate / pad size for PC 7336?
Think the 7336 is like the 7424, and i would go with 5in bp and 5 1/2 pads
From all of my research, it is indeed the same machine.
I have never used a PC before, but from the sound of it the 5" backing plate (like the Lake Country one or the 3M one) are a good bet because most people have alot of success using that packing plate with 5.5" pads.
Hydro-tech pads for that matter ...
Now which one? Meguiars, LC, 3M or the Buff and Shine.....
What would one look for to determine the best option?
I will check those out. So far I was looking at the LC 5.5" pads. Wont need cutting as I will use the rotary for that. Just polishing and finishing I think...
So in the 5.5" pad sector which of the following would be best?
Lake Country CCS Smart Pads Dual Action 5.5 inch Professional Foam Pads: 6 for 35.99
Lake Country 5 1/2 x 7/8 inch Flat Foam Pads: 6 for 34.99
Lake Country' s Hydro-Tech 5.5 x 1.25 Inch Foam Pads: 3 for 29.99
Aside from that I would be looking into bonnets as well….. any suggestions?
I only see 6" bonnets. Is that the proper size to use with a 5.5" pad inside of it?
Or would this kit cover most anything I would need…
Dual Action Microfiber Bonnet Kit
By segdoh49 in forum Ask your detailing questions!
Last Post: 08-09-2016, 04:05 PM
By vandervortadam in forum Wool & Foam Buffing Pads
Last Post: 05-25-2014, 02:20 PM
By Justin at Final Inspection in forum Rotary Buffers
Last Post: 04-30-2014, 10:21 AM
By shagnat in forum Auto Detailing 101
Last Post: 01-02-2014, 06:16 PM
By frank10 in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 09-06-2010, 06:48 AM
