I recently purchased a PC 7424XP and was trying it out for the first time. I was compounding out some scratches on my truck. I had it set between 2 and 4. I cranked it up to 6 to get out some heavier scratches and the Lake Country pad just flew off the machine while using it. It broke right where it joined in the center of the pad. I was using a foam cutting pad velcroed to the backing pad. There was a lot of vibration at the #6 setting. I had the correct counter weight on. Is so much vibration normal? Maybe I was not applying enough pressure to the pad? Any help or suggestions would be appreciated.
