Video: How to remove overspray paint using detailing clay
Tips and techniques for using detailing clay to remove overspray paint or any other type of above surface bonded contaminants off your car's paint.
Gloss comes from smoothness
I think we can all agree a great looking finish is a glossy looking finish and gloss comes from smoothness. An important step to creating a glossy, show car finish is to inspect the paint for above surface bonded contaminants and if discovered remove them using detailing clay.
How to remove overspray paint using detailing clay [ame=http://www.youtube.com/watch?v=BnH7hCe98Nc&hd=1]How to remove overspray paint using detailing clay - YouTube[/video]
Detailer's Universal Detailing Clay 200 grams
The 4 benefits to claying are,
1: Claying safely removes Above Surface Bonded Contaminants
2: Claying paint enable your choice of wax or paint sealant to better bond or adhere to the paint.
3: Claying paint restores a silky, smooth, clean surface.
4: Claying paint makes polishing easier, more effective and safer.
More related topics...
Using Detailing Clay
The Baggie Test - How to inspect for above surface bonded contaminants
The 3 primary benefits of using detailing clay to clay paint
Tips and Tricks for using detailing clay
Do I need to wash my car after I use detailing clay to clay the paint?
How often do I need to clay my car?
Video: How detailing clay works and how to use detailing clay to remove above surface bonded contaminants
I also cover claying and much much more in my how-to book...
Paperback
Re: Video: How to remove overspray paint using detailing clay
Can this remove rattle can paint off the clear coat?? My uncle painted the whole surrounding area for a scratch, and looks like crap.
David 2000 Ford F-350 DRW CCLB BLACK/GOLD
Wish list:
Everything Mike has in his garage for detailing
David,
Painting a scratch to fill it in so it's unnoticeable sounds simple enough but is it?
You can minimize its ugliness making it less noticeable but to do it correctly requires sanding and feathering the defect out then repainting. The trick here is to blend the new paint with the old creating a perfect match then clearing the entire panel so the blended edges or transition from new to old are invisible.
This depends largely on what you find acceptable. You may find yourself wet-sanding the area to remove most of it then buff with an appropriate pad and compound. Don't be afraid to experimant a little, you can only improve the situation...
Originally Posted by BobbyG
David,
Thanks Bobby, I figured i would need to lightly sand. ill try sanding all the over spray then fill in the scratch, then compound to level it out. Crazy how getting into detailing and now the whole family wants it..
Wish list:
Where you at with this project?
Last Post: 11-22-2019, 02:43 PM
Last Post: 08-07-2019, 08:26 AM
By Zee19 in forum Auto Detailing 101
Last Post: 10-18-2016, 06:38 PM
By 1953hogan in forum Auto Detailing 101
Last Post: 06-16-2015, 08:26 PM
By lawrenceSA in forum Auto Detailing 101
Last Post: 07-02-2013, 07:31 AM
