Dislikes:
Ratio chart?
Is there a chart showing ratios of product / water for different applications? I need to know how much ONR to mix with water for a Nanoskin lube. TIA
Re: Ratio chart?
Re: Ratio chart?
Clay lube dilution ratio of ONR is 2oz. per. gallon or 1/2oz. per. 32oz. Same for Nanoskin products.
You could also use it at ONR Quik Detail ratio of 8oz. per. gallon or 2oz. per. 32oz.
Re: Ratio chart?
Just use car wash soap and skip all that ,wash it again and clay at same time .
Re: Ratio chart?
Originally Posted by
GSKR
So much easier this way.
Re: Ratio chart?
Ricorocks
Rick strikes again. I have this laminated and posted in my garage. For when you really don't want to think.
Peace,
Darrin
Re: Ratio chart?
GSKR
OK, so I wash the car as normal, then re-wash only a section at a time, the section I'm going to "clay"? Do I use the Nanosponge to get the wash solution to the car or my regular sponge? Then I need to re-rewash the car after the process?
Re: Ratio chart?
Ricorocks
thanks for your information
By frankprozzoly in forum Auto Detailing 101
Last Post: 12-13-2015, 01:39 PM
By marlonrg3 in forum Auto Detailing 101
Last Post: 07-30-2014, 09:41 AM
By muscleman in forum Auto Detailing 101
Last Post: 03-15-2014, 11:00 PM
By DogRescuer in forum Auto Detailing 101
Last Post: 05-15-2013, 07:02 AM
By 05xrunner in forum Auto Detailing 101
Last Post: 12-17-2010, 06:19 PM
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
S
M
T
W
T
F
S
1 2 3 4
