Page 1 of 2 12 LastLast
Results 1 to 10 of 16
    Aug 2013
    St. Louis, MO
    580
    G21 backing plate swap
    I went to change out the backing plate on my G21 today and I was having trouble aligning the backing plate "shroud" and the actual polishers bolt part...they are both recessed on either side. I thought it lined up since it felt like it did, but im concerned its not completely flush.
    Is there a trick to lining it up?
    Feb 2014
    Rochester MA
    2,627
    Re: G21 backing plate swap
    Took me a little bit to line up my 5in pad on the g21 with the washer mod.
    IGL Authorized Coating/Kenzo Installer
    Final Inspection Auto Detailing- https://www.facebook.com/FinalInspection
    Apr 2012
    7,494
    I use a small screwdriver to align them and then put the bolt in.
    2019 Nissan Rogue SL
    Super Member Joe@NextLevelDetail's Avatar
    Jun 2015
    1,929
    Quote Originally Posted by custmsprty View Post
    What he said. Or just put the plate down and hold the polisher and align them together you'll feel it fall in together then hold it together and screw it in.
    Aug 2013
    St. Louis, MO
    580
    Excellent. I am pretty sure i felt it fall in but i was a little worried i was just imagining things.
    Jun 2015
    1,929
    The 6 inch late is a lot smoother then the 5 inch plate. Swapping the 5 inch is good.
    I prefer the 6 inch it just feels OEM and more balanced to me.
    I still swap it from time to time.
    However the 6.5 inch pads feel right on the 21
    Aug 2013
    St. Louis, MO
    580
    I ran it with the 5'' BP this weekend and did a full size truck... it was not as smooth as I hoped, but I think that might be a byproduct of using thicker pads. I used some thin hydrotechs and microfibers and it was pretty nice, but when I switched to some Lake Country flats it was a little bumpy.
    I'm going to get some of the boss pads or some megs thin foam I think.
    Feb 2014
    Rochester MA
    2,627
    used my G21 on a gt500. Used there BOSS 5.5 pads and creams with great results. I am not a 6.5 in guy at all. I was happy with the 5in plate.
    Jun 2015
    1,929
    Quote Originally Posted by Heisenberg View Post
    The boss pads are smooth as butter and thick pads do change the ride of the machine. Especially if your using the 5 inch plate.
    Meguiars discs work good with the boss too.
    However in contoured edges slap on a thick pad as it helps rotation its like a innerflex kind of.
    Don't run the inerflex pads at high speed they blow up in 1 minute even on like speed 4, 1-3
  10. #10
    Super Member ski2's Avatar
    Dec 2011
    Southwest PA
    1,826
    B&S will be releasing their new pads designed for long throw polishers at SEMA!
  1. Replies: 25
    Last Post: 10-07-2021, 02:58 PM
  2. Supa BEAST and CBEAST Backing Plate Swap by Mike Phillips
    Last Post: 07-15-2021, 08:27 AM
  3. Swap out backing plates or get multiple polishers?
    By Bluelude1 in forum Auto Detailing 101
    Last Post: 01-03-2020, 04:50 AM
  4. Replies: 0
    Last Post: 09-02-2017, 08:14 PM
  5. Griots 6" backing plate VS. Lake Country's backing plate
    By ryanmcg1 in forum Product Reviews
    Last Post: 09-29-2011, 11:29 PM
