Originally Posted by MikeN
Thanks for all the tips. Really helpful. All I know is that the boat is a 25 footer, I'm hoping to go view it in the next week or 2 so I can formulate a game plan
Sent from my SCH-I535 using AG Online
Be sure to double check that it is indeed gelcoat and not a basecoat/clearcoat
Sent from my DROID4 using Tapatalk 2
Re: Boat detailing must haves
How can you tell if it's a basecoat/ clearcoat or gel coat?
Most fiberglass boats are gelcoat. Aluminum boats are aluminum.
I don't think there are not many basecoat/clearcoat boats an average person can afford.
Derrick
We intensify every color of the spectrum.
"If it doesn't shine, we didn't do it!"
I've worked on more than 1 base/clear, so just check to see if the owner knows. A good way to check is by taking some rubbing compound on a towel and seeing if color from the gelcoat comes off when you rub the compound on the the spot of color.
What's the difference in the detailing process?
meguiars vinylex for the seats. great stuff. buy a gallon it is reasonable
Gelcoat is color infused topcoating to the fiberglass, it is very hard and requires aggressive diminishing compounds to be used. Base/clear is much more thin and must be treated like a car.
Also, a polish like m67 will add oils to the fiberglass, enhancing gloss by conditioning the gelcoat.
Thank you!! Is the base/clear something that would primarily be found on higher end stuff?
Yup, high end boats, bass boats and re-paints are most common to have base/clear.
By Mike Phillips in forum 2-Day BOAT Detailing Classes - Info & Dates
Last Post: 08-12-2020, 03:12 PM
By Mike Phillips in forum PICTURES: 2-Day BOAT Detailing Classes
Last Post: 03-02-2020, 10:05 AM
Last Post: 02-17-2020, 01:20 PM
By Elliot@Autogeek in forum Sales & Promotions - For forum members and non-forum members
Last Post: 04-03-2019, 10:26 AM
Last Post: 10-24-2018, 03:39 PM
