Results 1 to 5 of 5
    Apr 2014
    Need help with gelcoat (photo included)
    Hey guys,
    First off I'd like to say awesome site with lots of info and great bunch of guys. Hard to find forums like this these days.. Keep it up.
    I have a buddy with a 18' boat that needs detailing, boat is in mint shape other than these wierd white spots which are located on only about half of the boat. Not sure what they are ( there is even some on the sticker). Ive tried the 3M heavy duty compound and polish by hand to do a test. The results Ive been having is the spots disappear but as soon as I let it dry for 2-3min the white spots are back.
    Any ideas how to get rid of em? Im thinking I'll have to wetsand with 1500 then 3 step process in order to get rid of it.
    Any help is appreciated, thanks a bunch
    Super Member Just02896's Avatar
    Nov 2013
    1,734
    Re: Need help with gelcoat (photo included)
    I'm thinking a rotary and some heavy cut compound will do the trick.
    Super Member Durallymax's Avatar
    Aug 2012
    341
    The spots are "etched" into the gel coat, when you rub a product over them it "fills" them in and hides them until it flashes away and you see the edge's again.
    X2 on a rotary, wool and heavy compounding. Eat your wheaties.
    Vinny
    Regular Member Theraven's Avatar
    Nov 2012
    110
    Wetsand it, I use to buff out a colored hull that had etched water spots in the gel and it would always come back in the same area/cluster after a few months or less. After I wetsanded and buffed out those areas they did not reappear. I tried grinding to pretty hard with heavy duty compounds, but the results didn't last untill i wetsanded it first.
    Mar 2013
    BC
    Use a heavy cut water based compound first (Farecla Profile 100 / Presta Supercut / Aqua Buff 1000) with a twisted wool pad. Petroleum based compounds will mask the buffing results and when the petroleum base dries out the actual results reappear. If the above products won't work then you will have to switch to wet sanding.
  1. How to upload a photo into your Autogeek Photo Gallery
    Last Post: 01-30-2022, 12:05 AM
  2. Transfering photo's from; My photo's to My albums
    By Hoytman in forum Auto Detailing 101
    Last Post: 12-18-2013, 02:09 PM
  3. Included pad
    By drvnbysound in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 10-26-2013, 09:05 AM
  4. How to delete a photo form my photo collection
    By WRXINXS in forum Tips, Techniques and How-to Articles for Interacting on Discussion Forums
    Last Post: 02-09-2013, 09:51 PM
  5. How Do I Fix this (pic included)
    By DrMcDave in forum Ask your detailing questions!
    Last Post: 10-01-2010, 09:21 AM
