Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 48
    Super Member Don M's Avatar
    Jan 2010
    NE Ohio
    2,247
    Re: 3 batteries in 2 years, any ideas?
    I've had the charger in the car since it was new (2006), I only started having a battery problems two years ago 2011/2012.
    Super Member SameGuy's Avatar
    Jul 2011
    Montreal
    1,927
    Same happened to my wife's Accord over the course of five years, killing her OE battery at six years, and a succession of three heavy-duty Kirkland (Johnson Controls) 880 CCA batteries going flat every couple of weeks and dying completely after the third or fourth revival. Luckily they are 36-month free replacement, and 100 month pro-rated. It took a few years and multiple repair attempts but I finally figured it out: the trouble started when my wife changed jobs, going from commuting 25 miles each way to just two miles and longer vacations and breaks.
    When she got the car I had a remote starter installed, but it was never a problem while the car was being driven longer distances; short distance driving and longer periods of the car sitting unused couldn't make up for the remote starter system's parasitic draw. With the short commutes I asked if she really needed the remote, and when she agreed that she didn't, I pulled its fuses. The battery hasn't died since, about 16 months on now.
    Francesco
  3. #13
    Super Member swanicyouth's Avatar
    Mar 2011
    Limerick, PA
    9,388
    Quote Originally Posted by Don M View Post
    Ok. Then my guess is your LIKELY having one of 2 issues. First, parasitic drains are not common if the vehicle doesn't have aftermarket stuff on it. But, there is an easy way to tell.
    Just get a test light. With the car and everything off, d/c the + battery cable. Hook up the TL alligator clip to the d/c'ed battery terminal and tap the TL tip to the positive of the battery once for a second. The light will prolly light - that's normal.
    After that, place the tip of the TL on the battery and see if the TL lights. If so (anything but super dim) - you have a drain.
    After that it's somewhat easy to find the drain. Just start pulling fuses one at a time until the TL goes out. Then you know the drain is on that fuse circuit.
    But, I doubt that is your problem. If so, the car would be going dead again soon after you get the new battery - not many months later.
    My guess is:
    1. Poor ground / connections or bad battery cables.
    2. Bad diode rectifiers in the alternator (means replacing the alternator). If a positive diode is bad - this could POSSIBLY (not likely) cause a drain. But, it will wreck the battery over time. This can be checked with a multi meter that reads AC voltage.
    Just connect the multimeter to bat positive and chassis ground with the car running on AC scale. A little AC voltage is OK. Anything approaching 3/4 a volt or so means your alternator is toast.
    I'm assuming your belt is tight and spinning the alternator correctly? Do the lights dim at night when you turn the wheel to lock?
  4. #14
    Jan 2014
    What type of vehicle is it? The reason I'm asking is because my daughter has a Volvo XC-90 and was having the same problem. When she would get back to the airport after a few days out of town on business, the battery would be dead. And, it happened with every replacement battery. The dealership finally traced it to the satellite radio. She cancelled the account a few years ago, and for whatever reason, the radio all of a sudden started trying to connect to a satellite.
    No one seems to know why, although I suspect it was during promotional times when Sirius/XM started trying to turn on radios that had been discontinued from their service. The dealership wanted to replace the whole thing for $800 plus labor, but she had another shop disconnect the satellite phase of the radio altogether.
    They keep hounding me about my GT-500, but I didn't but the car to listen to the radio.
  5. #15
    Aug 2010
    New Jersey
    15,163
    Yeah, well, batteries suck now. GM was putting Chinese "Delco" batteries in new cars and was having a lot of premature failures. Sounds like after the original battery that was pretty good, you have just been getting junky cheap (1-year) ones.
    As has been noted a lot of stuff plays into it, short trips, parasitic drains, storage time, etc.
  6. #16
    Jan 2010
    NE Ohio
    2,247
    Quote Originally Posted by swanicyouth View Post
    Yes, yes and no.
    The shop that has the car has been working on my FIL's cars for years and since I got married, they have worked on my wife's cars when it was something I couldn't do. The wife thinks I have a "Tim the Toolman" gene and screw up everything and doesn't like it when I want to fix something.
    The only thing she does agree that I'm good at is detailing.
  7. #17
    Aug 2010
    New Jersey
    15,163
    Yikes, are you kidding? With all the crap the cars have on them today (telematics, etc.)? I had my battery replaced under the new car warranty, and the service writer said "you didn't let the car sit for a long time, did you?" so I asked what was a long time, and he said "2 weeks". I told him that the car had only been sitting overnight, and it wouldn't start this morning, what I didn't tell him is that it was common for me to let it sit for a couple weeks at a time and the battery had been getting progressively worse so that now it wouldn't even last overnight.
    But back to the point, 2 weeks is a long time?? In the old days I used to let my 70's beater car with the Delco Freedom battery in it sit for 6 months, OUTSIDE, and it would still start (well, that was after the clock stopped working, it might have been only 4 months when the clock was working).
  8. #18
    Super Member Misterpaul's Avatar
    Sep 2009
    Plainfield, Il
    1,369
    Quote Originally Posted by SameGuy View Post
    My 1988 Honda Lemon, er, Accord Coupe did this too. Never figured out what was causing it but along with several other issues I sold the car and never went back to Honda. No aftermarket anything was installed on it though. I bought it new with less than 20 miles on the clock; worst car ever and sadly before the advent of Lemon Laws.
    Sorry for the thread hi-jack.
    2017 Phantom Black Metallic Chevy SS, automatic, skylight, plus unused wheel in the boot.
  9. #19
    Mar 2011
    Limerick, PA
    9,388
    Sounds like your talking about a normal OE drain that is normal for the vehicle. New cars do have a lot of electronic junk on them - but most of it is switched off with the ignition. Something not getting switched off that should be switched off due to some malfunction, like a sticking relay - really isn't too common. I've only seen it maybe 2 or 3 times. I've left my trunk open in my BMW (light on) overnight a bunch of times and it fires right up.
    On the other hand - the OP needs a good battery to start. I've had exceptional luck with BMW factory batteries lasting 7 years or so. I'm not sure what type they use... But I recall doing some research a few years ago and came to the conclusion Wal Mart actually sells pretty good batteries for their top of the line.
    Either way, most batteries will last at least a few years. Something isn't right with the OP's electrical system IMHO.
  10. #20
    Jan 2010
    NE Ohio
    2,247
    My car is a 2006, Suzuki Aerio/DD and I have a 90 mile round trip to work everyday, the longest it sits is three days, so the short trip/frequent starts isn't an issue
  1. FLEX PXE 80 12-EC batteries
    By nakranij in forum Auto Detailing 101
    Last Post: 05-18-2020, 02:40 PM
  2. Anyone else running out of batteries?
    By Maestro Sam in forum Auto Detailing 101
    Last Post: 09-16-2016, 09:39 PM
  3. Replies: 7
    Last Post: 08-02-2015, 11:30 AM
  4. Heavy Duty Batteries vs. Generator
    By Thirdlife911 in forum Ask your detailing questions!
    Last Post: 04-25-2014, 07:43 PM
  5. Why do car batteries always fail at midnight?
    By cardaddy in forum Off-Topic
    Last Post: 12-26-2012, 06:26 PM
