Which Fittings Does The AR North America AR383 Use?
I'm about to buy a foam cannon and I'm looking at pressure washer right now. The one that I like AR North American Electric 1900 PSI P\pressure washer and I wanted to know if any one that owns one or knows the answer could tell me if AG has the foam cannon fitting that connects to that specific pressure washer and which one.
Re: Which Fittings Does The AR North America AR383 Use?
None of the ones AG has, go to home depot and they have a wand kit, $20, and has the proper adapter for AR NA PowerWashers.
AR has one similar to a Bosh but is not the same, slightly different tabs. But the HD kit has the proper one and some other more uncommon adapters. Also converts the end to a standard threaded nozzle for easy quick disconnect for foam cannon and tips.
Power Care Pressure Washer Wand with Adaptors Set - AP31021 at The Home Depot
Cheap foam cannon alt, will screw directly into wand above (if memory serves correct)
Green Earth G-Foam Blaster for 4,000 psi Pressure Washers - AGPWF04 at The Home Depot
Originally Posted by agpatel
Wow thanks for answering my question and for the quick reply!
Nothing seem to work the with AR America AR383 Pressure Washer. I Tried but fail, i cant seem to do anything with it
If there is a way to make it work with the AR383, that would be great
Will this wand work with kracher power washer?
Have you tried the adapters from HD like stated above?
Yes, and the fitting they offer do not work, i am trying to find solutions to make it work, but all my research come to a dead end, but ill still shall look for anything that MIGHT work
Yes, it will work, but I see no use of it if you are using it with the Foam Cannon Pressure Washer Fitting for Karcher
Dang this sucks.. You have any pictures of what the fitting is suppose to look like? I'll be looking around for some and if I find them I'll post back on here.
AR North America - Pressure Washer Optional Accessories
Look under adapters and can someone see if one of the 2 bayonets is the correct fitting.
Went thru the same headache, I gave up and replace my AR Gun with a Karcher, then bought the Karcher fitting from AG.
Last Post: 12-11-2019, 10:02 AM
By Shea Luxury in forum Hot topics & Frequently Asked Questions
Last Post: 03-12-2015, 11:22 AM
By Znig22 in forum Show N' Shine
Last Post: 02-09-2015, 09:28 PM
By ChineseGuy in forum Off-Topic
Last Post: 04-03-2011, 06:24 PM
