High line paint meter thickness gauge
I have one on the way.. I did do a search.. And did find some good info..
But any recommendations on how to use it how to learn how to use it.. Thanks..
Re: High line paint meter thickness gauge
Always remember that it is a tool that allows you to ESTIMATE how much paint you have to work with
There is one that is made by "all-sun", these are the specs:
This tester is designed to not-destructively measure the thickness of non-magnetic coatings (including
paint, enamel, plastic, epoxy, etc) on iron, steel or aluminum.
- Measuring Range: 0.0mm to 2.0mm, 0mil to 80mil
- Accuracy: 2%rdg ±0.1mm, or 2%rdg ±4mil
- Note: Accuracy is guaranteed at the operating temperature of 23°C±°C and relative humidity of not more than 75%.
- Resolution: 0.1mm/1mil
- Power Supply: 1 x 3V button cell, CR2032 or equivalent (Not included)
- Operating Environment: Temperature: 0-40°C
- Relative Humidity: <80%
- Temperature Coefficent: 0.05x(2%rdg±0.01mm,or 2%rdg±4mil)/°C (<18°C or >28°C)
- Storage Environment: Temperature:-10°C to 50°C Relative Humidity:<80%
- Size: 6.9 x 3.8 x 2cm
- Weight: About 23g (including button cell)
For $18.00 USD, I think won't hurt to try it .
Research on the net and view videos. There are several that show how to calibrate and use it. Good luck.
Here's one link I find as an a example.
https://www.youtube.com/watch?v=8VY-20oQ_cU
Thanks all it should be here Friday
By allenk4 in forum Products Guides
Last Post: 02-29-2016, 10:54 PM
By mbkite in forum Auto Detailing 101
Last Post: 01-28-2016, 10:50 PM
By BeachZone in forum Auto Detailing Tools and Accessories
Last Post: 01-22-2014, 04:34 PM
By bambam33 in forum Ask your detailing questions!
Last Post: 03-27-2011, 06:59 PM
