Re: indiej's pad washer
Looks like a commercially made unit, are you trying to sell them here?
just sharing because I learned from other's who shared a lot in these forum sites. Other's may build similar with their own touches.
This is my pad washer using a bucket with cover, grit guard, an aquarium water pump with suction cups and some fittings that came with it and some useful clutter I found in storage. Inspired by the System 2000 and Univerversal Pad Washer.
Cover the other grit guard with a cotton terry towel with long naps and wedge it on another bucket for drying -- inspired by "How to clean your foam pad on the fly" by Mike Phillips. Some tweaks here and there over time.
I was gonna point the tip of the tube upwards and control the jet by drilling holes but the tube came with holes and the jets from the holes are more suitable, so the tip became the jet control. Cap the tip with a flow control or position it flush to the bucket to retard the flow through it such that the jet height at the holes suits your purpose. Prop the pump higher from the bottom of the bucket. I used a plate from a steamer in the kitchen, you could also carve an indent for it on top of a block of foam just to give you an idea.
To turn on the water pump, I wired it to a doorbell button, 1 wire through it then to the plug of the pump, the other direct to the other terminal of the plug. Cover with some plastic and back it with a PVC electrical box, you get the idea, make it waterproof. Step on it to jet while cleaning your pad on your machine.
Might as well have some fun with it. This submersible water pump is rated 400 Liters/hour. Less powerful pumps will do. There are also units with adjustable flow rates.
Back to serious business.
A pretty strong magnet.
I removed the activated carbon filter so it won't mess with the pad cleaning solution. I put the magnet instead, then the foam filter. That'll catch some grit and fibers just in case. This is more useful in 2-bucket car washing. The pump will fit without the tube and using a half inch cover with foam filter on the suction side. Or go without the pump, go nuts and drop a can of magnets over/under the grit guard!
Very interesting concept.
Have you tried washing some used pads with you invention? I'm very curious to see how effective it is.
I see you're using aquarium parts. Will the soaps and detergents normally used to clean pads affect the pumps, seals, or valves that are part of the system?
Keep up the good work!
i use it with all my pads. i recall checking with the light yellow pad, it went from dark gray to light yellow with some light gray shadow. before washing, i pinched it in some areas and of course it was greasy. After washing, no grease at all. pretty good and easy. i'll probably make a trolley and fix them buckets there. i have another bucket jetting plain water for rinsing.
i started before, thinking springs and upside down plastic container with tubes inserted pointing up then ended up with the aquarium water pumps. they're about 10 bucks each.
i thunk all these because I washed pads by hand using dishwashing liquid and had a hard time rinsing out the suds.
i wouldn't know about the reaction of the valves and seals to the cleaning solutions, though one could disassemble the pump and look inside. it's sealed with melted rubbery plastic. just check the submersible pump you buy.
i'll rinse the pump in plain water more regularly then. thanks for the concern. i was really watching the wirings outside the bucket to avoid electrocution, i'm pretty familiar and unafraid with aquarium pumps.
The reason I asked is I didn't know if you experienced any issues or failures in these areas due to cleaning chemicals. It sounds as if your system is performing well, thanks for posting..
Good information to know!
Super Moderator
Very interesting, reminds me of MacGyver, he will make anything from just about nothing!
thanks brrrrr... below zero where you're at.
btw, the pump can withstand the saturated stew of chemicals and whatnot in an abandoned aquarium. that mix can get quite acidic. a little cleaning and it's running again in a new glass box.
it's also used 24/7 year round pumping coolant (alkalinic) ran through copper or aluminum and UV reactive hose under UV lighting for watercooled computers.
nice thing about the submersible pump is that its motor is watercooled. the engineers must had an easy time figuring how to cool it. just be aware to run it fully submerged.
By josher in forum Auto Detailing 101
Last Post: 12-13-2017, 08:25 AM
By ndsports in forum Auto and Garage Accessories
Last Post: 02-04-2017, 03:09 PM
Last Post: 08-14-2016, 12:59 PM
By fotomatt1 in forum Products Guides
Last Post: 08-12-2016, 09:03 AM
By bmwgeek in forum Auto Detailing Tools and Accessories
Last Post: 10-28-2011, 03:11 PM
