Dislikes:
Water spot advice
Here's what I have booked for this weekend.
I have a 6 and 3 inch griots DA polishers
m105 compound
m4 compound
CM yellow pads
DA MF cutting pads
What would he best to get all these years of etching water spots off?
Re: Water spot advice
I'd start with seeing if a vinegar solution would remove some of it before you start polishing.
Try vinegar mixed with water 50/50
1. Wash the Car
2. Mist it on
3. Massage with a soft sponge
4. Rinse off
Hard to tell from pic,car looks dirty if not and those are spots like that I don't think vinegar will help,if it deos your in good shape better than trying to polish all of that off good luck and report back if need more advice.
No, that's not dirt its all water spots, water and vinegar did nothing I even used a water spot remover spray and still nothing, I've tried the m105 and yellow foam pad and it really didn't do much. I'm trying to avoid wetsand if at all possible.
Surprised the M105/Yellow Pad didn't make a dent
What polisher, machine speed, downward pressure, number of passes, arm speed were you using?
6 inch, speed of 5, 5 passes, arm speed slow, pressure 25% of 100
Last Post: 03-08-2015, 10:57 AM
By nissenc1337 in forum Auto Detailing 101
Last Post: 03-18-2013, 03:32 PM
By ddyer248 in forum Auto Detailing 101
Last Post: 06-04-2012, 07:51 AM
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
S
M
T
W
T
F
S
1 2 3 4
