Page 4 of 4 FirstFirst 1234
Results 31 to 36 of 36
  1. #31
    Feb 2011
    Minot, ND
    12,365
    Re: ~*Just bought Flex!!*~ some Help from experts plz( PADS...etc)
    Without stepping on anyones toes, yes the 4 3/8" plate can be used with the 5" Hybrid pads. However the Velcro backing material on the pad is 4" while the plate is 4 3/8". This will leave you with 3/8" overhang of the plate on the pad. This extra bit of Velcro can potentially dig into the foam pad when downward pressure is applied.
    The correct pad and plate combination is indeed the 5" Hybrid pads with the 4" plate. This system was designed to be used together.
    There are only 4 plate size options and two plate manufactures. Flex and Lake Country.
  2. #32
    Super Member kevincwelch's Avatar
    May 2013
    Oak Park, IL (Chicagoland)
    2,686
    Is there a difference between the $389 version of the flex vs the $349 pink flex? Looks like by its description it is the same other than color.
    Sent from my Nexus 5 using Tapatalk
    Perfection is attained by slow degrees; it requires the hand of time. (Voltaire)
    2013 TESLA MODEL S | Gyeon Syncro | Gyeon Cancoat
  3. #33
    Aug 2013
    46
    Customer service got it sorted out sending 4" with return able.Happy customer here. Next week end time to get my detail on!!
  4. #34
    Super Member VISITOR's Avatar
    May 2007
    9,728
    Quote Originally Posted by kevincwelch View Post
    I believe that is correct...
    i am the jump starter.
  5. #35
    Aug 2013
    46
    its staid that it attracts women like a pheromone infused axe body spray
    and to be made with a pink unicorns horn , that make any projects use completed with ease and beauty.
    thats just what i've heard though
  6. #36
    Super Member aim4squirrels's Avatar
    Nov 2013
    DFW Texas
    1,078
    I believe the pink flex units were a run of polishers made with proceeds to support cancer research? Am I remembering that correctly?
  1. Just pulled the trigger. Bought the Flex 3” DA polisher
    By DetailDrivenEugene in forum Auto Detailing 101
    Last Post: 12-03-2017, 12:41 PM
  2. Just bought the Flex 3401
    By toland76 in forum Flex Polishers
    Last Post: 10-29-2014, 06:13 AM
  3. Just bought a Flex
    By BluePowder in forum Flex Polishers
    Last Post: 08-11-2012, 05:58 PM
  4. Finally bought a Flex XC 3401VRG
    By SupraTurbo94 in forum Flex Polishers
    Last Post: 09-21-2010, 10:25 PM
  5. Those who bought LC FLAT pads from AG only....
    Last Post: 02-13-2010, 12:11 PM
