Re: Hydro2 vs Traditional AIO
Originally Posted by DownSouthDetail
I've experienced streaking once and it was on a black car and I applied it in direct sun, which you shouldn't do. I also had it mixed at 3:1. Now, I like to mix it at 4:1 and I dont ever experience any streaking whatsoever and from what I've seen, it doesn't degrade the protection properties either.
Interesting. Any direct sun insight for us mobile detailers?
Yep I can attest to the streaking on black cars when used in the sun.
Some members here have suggested to spray some diluted hydro2 directly onto streaks and should wipe off with a MF towel. You'd need to do this immediately to not allow it to cure
Originally Posted by The Critic
Hydro2 is a wash/seal. The problem with Hydro is that it doesn't fill enough for most cars, and the level of slickness is not at the level that most discerning customers expect.
I find this very funny really for any sealant to bond to paint its needs to be free of contaminants so you should clay before sealing any care if it needs it. Then you will get the slickness your looking for. You should know slickness comes from clean uncontaminated paint and not just the sealant.
Yes Mark it's not recommended to apply in direct sun light it's the only down side of it.
Ok, thanks a lot. I mixed 3:1 as well. I guess I have to add more water then. Thanks again.
Of course, but the level of slickness will vary significantly depending on the product used.
I've noticed much great slickness with most spray sealants (versus Hydro2).
The hydro2 'type' product is superb. There is truth in it not doing any filling and the car pro product does work out expensive. The style of product should actually work out very economical.
I agree that cost per application might be a little more expensive than a spray wax, but in comparison to an AIO, I feel like it might end up cheaper. - no need to purchase pads, pad cleaner, time spent cleaning pads, wear on polishers and backing plates, etc. plus the time savings will add up in a hurry.
Todd- from what I can tell from your site, it looks like you do a really good wash and clay before applying Hydro2 in your Exterior package. Is this correct as for prep, or did I miss something on there?
I do not for a second think hydro2 can replace an AIO. It has no ability to either correct or fill, two things that are central to an AIO. If you have a swirled finish, you still need polishing machines and accessories.
I just bought the $100 bottle of hydro 2. I'm just using it for my car. Even if it only lasts a couple of months it's worth the time savings. My question, is the force of the jet setting on a hose strong enough for hydro 2
By 2wookies in forum Show N' Shine
Last Post: 05-24-2020, 03:51 AM
Last Post: 05-26-2019, 06:16 PM
By CaveRacing in forum Auto Detailing 101
Last Post: 08-23-2015, 01:28 PM
Last Post: 05-16-2012, 03:04 PM
By tuscarora dave in forum Off-Topic
Last Post: 07-22-2010, 11:16 PM
