Re: Wolfgang Deep Gloss Paint Sealant vs Meguiars #21 Synthetic Sealant 2.0
Originally Posted by kevincolby650
does #21 or #26 leave a white residue on trim? I plan on taping but wondering for specific areas,
You'll want to remove tape before sealing. Whether you've done single or multi-step paint correction for instance.
Both don't need to get on trim, but can get on it if you wipe it right off. I don't have anything with a bunch of hard plastic trim that turns white though, but rubber trim I don't have any problems with. Just wipe as you go. Also with M21 you can leave it on anywhere from 15 minutes to 3 hours and it seems to come off just as easy.
In the interest of full disclosure, I mentioned earlier in the thread how I'd rather not use a WOWA sealant. One of the reasons is all the wiping of the paint with the applicator and a fear that applicator induced marring will take place. In looking at several microfiber applicators I have, they are ALL made of the cheapest microfiber towels you can buy. I actually have two green ones that were sent as freebies that match exactly the green mf applicator pads in one of my last orders.
With that being said, I washed my G the other day, just too dusty to keep wiping it plus I got caught with a little bit of wet road (about half a mile) the other day on the way home. (Wasn't raining, but the road was still damp from a passing shower.) Decided I'd just put a coat of BF Crystal Seal on it, and instead of the regular pad, I just folded up one of the Costco gold's into a small pad and it worked like a charm. Much softer than the other pads, and a little longer nap to boot.
One thing I don't like about it (BF CS) now that it's cured a couple of days, is it is a LOT less slick and sexy feeling than Megs 21. It's actually 'grabby' feeling! Megs leaves the surface sensual and silky feeling, like sliding a satin top sheet off a bottom sheet. Not quite oily, but surely not 'grabby'.
I'll hit it tomorrow with some BF WD Polymer Spray and see if that helps the feel. Seems I remember that WG DG Liquid Seal wasn't as 'grabby'. Also have WG DG Spritz Sealant, but I'd be hard pressed to say there was much difference between it and the BF WD Polymer Spray.
I know that Megs 156 is slicker, and DG 951 is slicker than that. (Plus I keep a bottle of each that has been polycharged.)
I believe they do.
I have not tried BFCS but for me WDGLS sheds water like crazy, looks nice and is easy to apply......slick it is NOT. For about a week it "felt" pretty nice, after that I would call it "grabby". I have thought the same thing about the quality of MF applicators. I believe I will try the folded towel next time.
By miker911 in forum Auto Detailing 101
Last Post: 09-08-2017, 04:47 PM
By StoleIt in forum Product Reviews
Last Post: 06-11-2016, 06:51 PM
By Grifftech in forum Auto Detailing 101
Last Post: 08-04-2014, 10:08 PM
By ilian11 in forum Wolfgang Car Care
Last Post: 08-04-2014, 09:53 PM
By 00celica in forum Auto Detailing 101
Last Post: 06-12-2011, 05:39 PM
