Can a gg6 fit a 3 inch backplate
Hi I was wondering if a 3 inch backplate fits in a gg6. I only work on 2 cars so I didn't want to spend more money for a gg3.
Thanks!
Sent from my HTC One X using AG Online
Re: Can a gg6 fit a 3 inch backplate
This one will work with any DA, be it a GG, PC or Megs polishers.
3 Inch Dual Action Flexible Backing Plate, da backing plate, random orbital backing plate
Any backing plate that has a 5/16" 24 thread will work with your GG6.
Yes the GG DA will take a 3" backing plate. Griots sells one for I believe $5.00--it's not in the catalog, but if you call customer service they will give you the part number etc. However, with a 3" BP I think the machine gets very "tippy" and the size of the machine can prevent you from getting into tight spaces. I went with a 3.5" bp and use 4" pads and it's worked well.
Originally Posted by tuscarora dave
Correct, that's the one I have attached to the Griot's Meguiar's and PC DA Polishers in the picture above.
And the above is a true 3" DA Backing Plate that comes on their 3" Mini Polisher. We currently don't stock the GG 3" backing plate, the one Dave and I reference is 3.5"
This is also correct. When using a small pad on a larger tool and working on "horizontal" panels, the tool can be tippy if you're not focusing on the task at hand. You have all this weight and the tool is under power over a very tiny footprint.
It's not a problem when working vertical panels however as for vertical panels you're already supporting the weight of the machine.
On horizontal panels, if you're not paying attention, the pad is compressing as it is supporting the weight of the machine.
Subtle difference in what's taking place, the opportunity for a whoops if you're not careful.
Thanks for the help! Might grab both to try out
Can you buy a different counter-weight to make it less tippy?
That's not what makes it tippy.
It's having a comparatively large polisher sitting over the top of a comparatively small buffing pad.
This is where a picture tells a thousand words...
Good question though...
Rotary Buffers can be tippy too on horizontal surfaces when you're using small pads and especially small pads with extensions...
Surgical Buffing
The solution to the potential problem is simple...
Focus on the task at hand...
(Which you should be doing anyways)
By iManu in forum Ask your detailing questions!
Last Post: 04-12-2021, 04:12 PM
Last Post: 03-04-2019, 03:15 AM
Last Post: 10-28-2015, 08:56 PM
By Witty4242 in forum Product Reviews
Last Post: 02-16-2014, 11:49 AM
By Mike Phillips in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 11-23-2011, 12:37 AM
