1st detail soon, a few questions
Hello all,
Receiving all my goodies in several different orders. I'll be doing my Black 2010 Toyota Corolla. Waiting for some more goods and decent weather. The days seem to be dragging.
I've decided on the Pinnacle ultra clay special, Wolfgang Trio, using PC and LC flat 5.5 pads, (Thanks Mike), orange ,white and blue.
Now, a few questions.
I know there is a coat of wax on the car, what kind of wash (what to use?) do I do to prep for polishing?
Do I polish the plastic bumpers also with the PC?
What is the formula for an IPA? after polishing.
OPC for the engine compartment?
There seems to be some kind of black tar or leftover sticky stuff from the previous balancing on 1 of my aluminum wheels, got some off with DP wheel and scrubby, not coming off easy, any ideas?
I thought I'd finish with 2 coats WGDGPS, and go from there. There seems to be many who say do that and call it a day. I do have some WG deep gloss spritz sealant to use after.
Well that seems to be it. I do very much appreciate all the feedback and advise I've been getting.
Thank,
Larry
Re: 1st detail soon, a few questions
I sure would really appreciate any feedback on these questions.
Thanks,
Larry
Originally Posted by LJSNY
Hello all,
Basic steps in order are:
- Wash
- Clay
- Paint Correction & Polish
- Seal
- Wax
- Adding some all purpose cleaner to the wash will aid in removing any left over wax.
- Once the washing is complete clay each panel throughly ensuring that you've removed the embedded particles and debris that's likely left after washing.
- Wolfgang's Paintwork Polish Enhancer is a great way to clean the finish removing oxidation and in general brighten the paint.
- I'm not sure what other products you have or if you intend to polish the finish.
- If they are painted to match the vehicle then yes.
- If they are dull plastic trip then no.
- 15% Isopropyl Alcohol and water or use some thing like CarPro Eraser or Klean Strip Prep-All
- Yes. Spray it on, let sit for a few minutes then with various brushes start scrubbing. A pressure washer comes in handy here.
- Meguiar's Wheel Brightener works well on most wheels with the exception of bare or non-coated aluminum.
- Meguiar's Body Wash is another great product for removing tar, bugs abd the like.
- Wolfgang Deep Gloss Paint Sealant is a nice sealant. I apply it using my Porter Cable 7424 polisher and a red foam pad. A speed setting of 3 is adequate for applying most sealants and waxes. Be sure to allow 12 hours for the sealant to cure before adding that second coat.
Thank,
Larry
No problem!
Hello all,
See this article,
How to Mix IPA for Inspecting Correction Results
Note I don't endorse the procedure and clearly state to follow the manufacturer's recommendations for applying your choice of LSP, that is car wax, paint sealant or coating.
I only wrote the article a year after asking for anyone else to take on the task and there were no takers. (I state that in the article too)
Thanks Bobby & Mike,
I think I might skip the IPA part, read some articles from Mike and I don't think it's absolutely necessary.
The Megs remover you mentioned is only available in Gallons, I really couldn't use all that cleaner. I need to come up with something I can get locally, I've pretty much got everything coming from AG that I need for now, I think.
Thanks for all the tips.
Larry
if is your first detail and is a black car , than be ready to spend 2 days on it
Four days for my black truck then?
David 2000 Ford F-350 DRW CCLB BLACK/GOLD
Wish list:
Everything Mike has in his garage for detailing
2 should be enough , depends what needs to be done to it , you can always detail a detail car ))
Work truck/DD/ weekend in the desert. That has scratches from offroading, work, idiot friends, not too bad
Wish list:
I put in for 2 days off next week.
Clay
WG duo
WGDGPS
Anyone have any experience with WG deep gloss spritz sealant?
Thanks,
Larry
By NRA7 in forum Auto Detailing 101
Last Post: 08-09-2013, 04:27 PM
By E4L in forum Ask your detailing questions!
Last Post: 04-19-2013, 11:17 AM
By darkangelism in forum Auto Detailing 101
Last Post: 07-05-2012, 12:02 PM
By malibuboats91 in forum Ask your detailing questions!
Last Post: 05-05-2011, 01:30 PM
By Rey05 in forum Auto Detailing 101
Last Post: 05-21-2007, 10:32 AM
