Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Mar 2011
    PA
    5,792
    opti coat 2.0/cquartz
    they both have been out for awhile now. just curious. which do you prefer? was one easier to work with over the other? just wanted a good comparsion. i dont know if i will ever go this route, but if i do i want to be armed.
    2018 Colorado ZR2
    Super Member Dr Oldz's Avatar
    Aug 2010
    NE PA
    4,462
    Re: opti coat 2.0/cquartz
    My choice is OC 2.0. I love the sheeting/beading properties of this product. Application isn't as hard at all as long as you take your time. And it is permanant unlike CQ that needs reapplication after 2 years.
    Jim
    Super Member LegacyGT's Avatar
    Aug 2010
    Des Moines, Iowa
    2,090
    Corey did a great comparison thread: Review and Extreme Testing: Opti-Coat 2.0 and CQuartz
    I like OC because you can correct it with poli-seal if needed and it is very durable.
    Detail Fest 2012 Face Book Page
    Club Flex 3401/PE14-2-150
    -Bill
    Super Member poweraid's Avatar
    Mar 2011
    wausau, wisconsin
    1,046
    could u or would u top 2.0 with a wax or sealant ? obviously u can use poly-seal , which is stated in product info . but just a straight up sealant or wax for more protection or added gloss ? just wondering .
    Aug 2010
    NE PA
    4,462
    Quote Originally Posted by poweraid View Post
    Once you see how it looks and reacts to the enviroment, you won't want to. Chris said it can be topped but the wax won't really adhere to it too well and then the surface will take on the poperties of the wax and not OC.
    Jim
    Super Member CEE DOG's Avatar
    Jul 2009
    Florida
    7,358
    Cquartz is more dummy proof.
    Opticoat has longer durability.
    :dancebanana:
    Sky's the Limit Car Care
    Super Member richy's Avatar
    Mar 2007
    Windsor, Ontario
    5,158
    I dislike using OG but like its durability. CQ is a great product but wished it lasted as long as OG.
    Super Member Rei86's Avatar
    Apr 2011
    1,087
    I have OC at the house and since we just purchased a new car I'm going to OC it since I HATE washing SUVs.
    But from forum post and people's use I'm going to go with that CQuartz is a easier product to use than OC 2.0 (next sale going to pick up some CQuartz).
    Hello my name is Sean
    Super Member panthercz's Avatar
    Nov 2010
    Lincoln, NE
    309
    I've applied both a couple times now.
    Opti-Coat Pro's:
    Very easy to apply
    Low odor
    Durability
    Cost effective, one syringe allows for application to 2-4 cars depending on size of vehicle
    Can be shined up with Poli-Seal
    Beads and sheets water like crazy
    Opti-Coat Con's:
    As easy as it is to use, you need to make sure you apply right the first time and triple check each panel after application.
    If a rock chip, dent, or scratch should occur, you have to remove Opti-Coat from entire panel and reapply. That would not be fun on larger panels.
    CQuartz Pro's:
    Very easy to apply
    Better durability than any traditional wax or sealant
    Doesn't attract dust like waxes and sealants do
    Can layer it and easily reapply it if a scratch or chip occurs
    New version supposedly doesn't have the water spot issue like the first version
    Can top it with CarPro Reload for added durability and to act as a "booster".
    CQuartz Con's:
    Odor is very strong
    Isn't permanent (but is only an issue because of Opti-Coat)
    Removal after it's 20-30 minute haze time is more like a wax and therefore not super easy like some sealants (BFWD)
    Not as cost effective
    "If I were stranded on a desert island and could only have one book, record and person...I'd probably die of exposure."
  10. #10
    Super Member unclestu's Avatar
    Jun 2009
    483
    I just ordered some Opti Coat to apply to my two new Casdillac CTS's. I have all of my ducks lined up to do the pre application surface prep. I ordered some brand new pads for the 3401 to use with the 85rd. I ordered some Iron X and some Grtiotes Garage paint prep(bogo) to make sure that everything is off the paint before I apply the 2.0.
    Despite all of the planning I have made for the application of the Opti Coat 2.0 I still feel nervous.
    I sort of feef as I did when Asphalt Rocket talked me into doing my first machine polishing job. That was performed on my brand new Porsche 911 turbo. All went well as I am sure this project will as well.
    I will keep you all posted
    Stu
    [SIGWe PIC][/SIGPIC]
    We are what we repeatedly do. Excellence, therefore, is not an act, but a habit. -Aristotle
    MAY THE SHINE BE WITH YOU
  1. How much CQuartz or Opti Coat do I need?
    By Old Tiger in forum New Car Care Products
    Last Post: 06-24-2012, 02:05 AM
  2. Opti Coat over CQuartz??
    By clm65 in forum Auto Detailing 101
    Last Post: 09-28-2011, 02:24 PM
  3. CQuartz and Opti-Coat
    By qaz393 in forum Auto Detailing 101
    Last Post: 06-18-2011, 07:19 AM
  4. Opti-Coat and CQuartz
    By rott3np3anut in forum Auto Detailing 101
    Last Post: 06-16-2011, 09:32 PM
  5. Opti-Coat 2.0, or CQuartz??
    By Kristopher1129 in forum Auto Detailing 101
    Last Post: 04-18-2011, 09:04 PM
