Hmm... well I did just recently switch over to using cotton terry myself, and I can say that the cleaning action is a bit faster that way... but I'm not exactly sure why.
We have always taught that it is best practice not to use microfibres cloths to clean leather. Dirt does damage to the finish on leather and as microfibres have a 'grab' to them if the finish is damaged there is a danger that the cloths will remove more than the dirt from the leather in certain instances.
The cleaning product should be doing the work rather than the tools you
are using to clean. Foam cleaners are far more effective for this reason as they can be left on the surface to gently lift the dirt which can then be removed with paper or terry towels.
Hope this helps
Judyb
Hope this helps
Judyb
Thanks. I think you were the one I originally read this from.
I don't use Microfiber on leather either. I've found a good old terrycloth face or hand towel to be just about perfect for cleaning leather seats. It's heavy enough and allows enough cleaning solution to be absorbed so that I can bear down on it for proper cleaning.
I find Microfiber towels are best suited "mostly" on the exterior.
its probably the product not the towel that detroys the leather over time. ive used micro fibers on my cars leather for 10 years with no problems. I also dont use any kind of cleaning solution. Just dampen the towel with warm water and wipe everything down.
