HD Polish with a white Buff & Shine pad. Follow that up with a Buff & Shine red pad and HD Poxy. Fantastic, easy products to work with and deliver great results!
The one step products lack in longevity of the sealant bs a dedicated sealant but with proper maintenance I don't see that being much of a negative for you.
If your paint is indeed in good condition I found my last Toyota paint responded well to OPT Poliseal. You could use this and top with OPT Spray wax for additional easy protection.
The Poliseal is easy to use and takes out mild marks. The spray wax is one of the quickest, easiest to use spray waxes out there.
Yes, the Menzerna 3500 should be fine )but I suggest a white polishing pad if you own a RO buffer). You'll need to seal it when you are done polishing it.
Magnetic gray metallic is great! A fairly hard paint in my experience with it. My wife's 2013 rav4 is this color and I just yesterday finished polishing with Menzerna 3800/black pad and sealing with WGDGPS. Only a few very minor swirls and mineral deposit etching after 3 years of daily driving with proper washing ( 99% Waterless or Rinseless) For the spot repairs I used FG400 and a LC orange flat pad ( white wasn't cutting it) and the mineral etching I had to used a yellow LC pad. I didn't have any success with the 3800/white pad removing and defects.
Since yours is already defect free I would say 3500 or 3800 topped with Wolfgang Deep Gloss Paint Sealant will give it great gloss!
