Re: You just can't beat the Flex 3401...
Originally Posted by dlc95
I'm probably going to pick up the XFE when it's released.
The XFE is available now... I have two of them...
What can I do about the heat build up? I noticed the silver body by the backing plate gets REALLY hot. I also just noticed I'm using the wrong backing plate for my 5.5 pads. Just ordered the 4 inch backing plate. Is that the problem?
Sent from my SM-G930V using Tapatalk
PERSONALLY I just put the machine down for a bit and let it cool when I notice it getting hot. I've never melted any pads, backing plates, etc.
2022 Jeep Gladiator Rubicon • 2021 Ford Ranger Lariat •2016 Alfa Romeo 4C Spider • 2006 Buell Lightning-Bolt • 2004 Jeep Wrangler Rubicon
The speed at which most compounds need to be run coupled with the added down force needed is the culprit of why the 3401 get really hot. Most of the compounds out there want/need speed 5-6 to be effectively used.
I like to run the Menzerna compounds/polishes as they like it backwards from the norm. I run FG400 at speed 3 and SF3500 at speed 5. Here at speed 3 with FG400 I can run it all day long without the machine getting excessively hot.
For the standard 5.5" pads such as the flats, CCS, Hydro techs, etc. you should be using the 4-3/8" sized plate. The 4" plate is for the 5" Hybrid pads.
I got the the part # wrong, it's the XCE.
Some people have problems with getting consistent results from non-forced rotation. The Flex will solve that variable. It helps dial in the process with one less key variable.
the flex is the way to go!!!
Love my new flex but I got to get used to it. It gives me a work out . 👍
I got some questions regarding this polisher, I hope can get some answers .
1. If you could get the Flex XC 3401 VRG or the RUPES Mark II at the same price, which one would you choose and why?
2. What is the main difference between this and the upcoming FLEX polisher? (XCE)
3. Same as the number 1 question but with the FLEX XFE7-15.
4. What are you missing from a rotary with the Flex XC 3401 VRG?
5. What's the vibration difference between the 3401 and a GG6 or PC?
TIA
2. What is the main difference between this and the upcoming FLEX polisher? ( XCE)
TIA
Sounds like you may be upgrading.
Which machines do you have on hand? This will better assist me in answering your questions.
By futurepro17 in forum Auto Detailing 101
Last Post: 03-05-2018, 09:24 PM
By DETAILROOKIE in forum Auto Detailing 101
Last Post: 05-25-2017, 10:49 AM
By UglyBetty in forum Auto Detailing 101
Last Post: 10-17-2013, 05:20 AM
By MichaelD in forum Boat & Marine Craft Detailing
Last Post: 10-16-2012, 01:28 AM
By Grifftech in forum Auto Detailing 101
Last Post: 08-29-2012, 02:44 PM
