Results 1 to 10 of 10
    Oct 2015
    Polishes and pads
    Hey guys I'm new here. I just picked up a Rupes mini, Flex 3401, Flex PE8 and I've got a Dewalt Rotary in my arsenal. I'm now trying to learn about polishes, wax, sealant and pads. What is considered to be the best pads, polishes, wax and sealant to use for a show quality shine?
    Sent from my SM-N900V using Tapatalk
    Super Member irvsmith's Avatar
    Nov 2014
    611
    Re: Polishes and pads
    What is the car you are working on and is it single stage/base and clear coat? That is a nice set of tools.
    Super Member choijw2's Avatar
    Jul 2015
    781
    that would be depends on manufacture, car color, paint hardness
    single vs clear coat, and current paint condition
    Please like my page
    Jae @ ONYX Detail Garage
    Jul 2015
    781
    I recommend menzerna fg400 sf4000 with LC flat pads orange, white, and some meg DMX micro fiber pads,
    for waxing i usually do with hand but when I use machine, I love using griots red waxing pads.
    for wax and sealant I am big fan of blackfire
    wet diamond and their waxes are one of the best out there.
    easy to use, super slick, great wet look,
    always do test spot with least aggressive settings,
    for example if paint is soft and defect is very minor, you should be able to remove them only using polishing pads with sf4000.
    Great detailers will make a car shine like diamond with least cutting.
    Please like my page
    Oct 2015
    Quote Originally Posted by choijw2 View Post
    02 Pontiac Grand Prix - dark cherry metallic
    It has a lot of swirls and never been polished. It's just my #### box I'm going to learn on.
    Feb 2011
    Minot, ND
    12,365
    Congrats on the machine purchases!
    The best pads for the Flex 3401 are the Lake Country Hybrid pads. These pads were designed for the characteristics of the machine.
    My preference for polishes is the Menzerna range coupled with the above. Here is a starting point to get you off on the right start using this setup.
    http://www.autogeekonline.net/forum/...brid-pads.html
    Super Member Mike Honcho's Avatar
    Apr 2015
    Atlanta
    1,264
    Listen to Mike, he knows his stuff!
    Mike Honcho
    Oct 2015
    Can you use polishes on glass to get water spots off? I've used 0000 steel wool and goo gone before to get sticky sticker residue off. If so what kind of polish do you need?
    Feb 2011
    Minot, ND
    12,365
    Quote Originally Posted by apierce1289 View Post
    I have never tried using paint polishes on glass so I can not comment here.
    If you want to polish the glass I would recommend using a polish designed for glass such as the Pinnacle glass polish.
    Pinnacle GlassWork Water Spot Remover, hard water spot remover, glass water spot remover, glass polish, water spot remover for cars
  10. #10
    Sep 2015
    6,281
    You can use a chemical to take off water spots,on side glass quarter glass back glass,but you can't apply any chemical on the windshield,use steel wool with some ceriglass or a mild compound steel wool oooo which the finest .Or get a pad that is recommended that works with the ceriglass and when using a chemical on side glass tape the molding only if it's brushed aluminum,if it's rubber Don't worry about taping have fun and good luck and wear gloves.
  1. MF Pads with DAT Polishes
    By Setec Astronomy in forum Wool & Foam Buffing Pads
    Last Post: 03-31-2012, 02:30 PM
  2. GG6- What pads and polishes to use?
    By bevans in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 04-27-2011, 08:05 AM
  3. New polishes and pads
    By stove937 in forum Auto Detailing 101
    Last Post: 04-10-2011, 12:43 PM
  4. polishes, and pads for pc
    By jswjr in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 08-14-2009, 01:45 AM
  5. New PC-XL CCS pads Polishes Wax help
    By NismoMax80 in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 07-01-2009, 07:39 AM
