Re: Removing BFCS for OC2.0 - need help
Originally Posted by RobertJ34
I'm honestly not 100% sure if the Black Label Surface Cleanse will remove the Sealant, if that is what you are wanting to use to remove it.
But i'd personally stick with what I said and what wdmaccord said (he gave a perfect simple step by step for it)
it will absolutely remove a sealant, its a quality paint cleaner, used it many times
Back to the full-time grind.
Thanks for the info, learned something new.
No problem. Try DP Prep Polish too, less cash same result.
Awesome, thanks for your help guys!
You do not need to abrade away a wax or sealant like you would need to if removing a coating. Use a quality paint cleaner that chemically cleans and leaves nothing behind like PBL, and you'll be good to go.
Thanks. Do the paint cleaners polish at all? As in, would I get double benefit by applying with a DAO, or should I do my polishing then use the PSC for final step, applied by hand?
the paint cleaners won't remove any light scratches/swirls. They have no abrasives in them at all.
So, I would recommend your Blackfire finishing polish (to help remove your light scratches), then you could do the paint cleaner or the IPA (or both if you really want to), then Opti-Coat.
Can i apply a second coat of the OC within an hour or two of the first coat? Im not sure i used enough on the hood and front bumper.
I just got done and only used about 8 ml on the whole car. 2014 Mustang.
I've heard its best to apply a second coat of OC about 30 minutes after. Anything longer than that and you may get a yellowing effect.
By jth877 in forum Auto Detailing 101
Last Post: 12-04-2014, 05:21 PM
By 01svtL in forum Auto Detailing 101
Last Post: 04-22-2013, 08:26 AM
By Bigbull2984 in forum Auto Detailing 101
Last Post: 11-25-2012, 08:50 PM
By Kinalyx in forum Auto Detailing 101
Last Post: 10-21-2012, 07:10 PM
By mjsjax in forum Auto Detailing 101
Last Post: 08-16-2012, 04:06 PM
