Re: New Truck deatailing questions
Having to use a more aggressive pad/polish is because you have harder paint. It has nothing to do with how new the vehicle. I know how you feel about learning to live with scratches on a daily driver. One thing you must realize is that you only have so much clear and can't continuously polish the paint aggressively.
thanks guys. I thought I read that Ford had hard clears. The truck looks great.
Maybe Im reading into this chart too much, but my main concern is the "Gloss" ratings. I used 1500 then 4500 without seeing a difference honestly in gloss. Im wondering if the fine polishing step was useless since you have to go over the whole truck again? Lot of work.
What do you guys think? Im seeing people using the wolfgang swirl remover and following it with the wolfgang glaze?
I recently picked up the Wolfgang duo and really enjoyed them. From what I've read, the Wolfgang duo is basically si1500 and sf4000 so I plan on trying them next to compare. If si1500 is anything like TSR on an orange pad, it finishes down to near LSP ready... So you might not really notice a whole lot of change as you are working with The finer polish but in my experience, when the vehicle is finished and pulled out of the garage... You'll notice the difference.
There are a lot of variables including paint type/hardness, pads used, general technique (polish actually broken down), and experience but if you did it correctly you should see an improvement in gloss.
Right. The 1500 seemed to leave a somewhat glossy finish. Granted the finish was "fluffy" feeling. It wasn't slick, but more LSP ready. It did remove most if not all imperfections. I think the Menzerna will probably finish the same as the wolfgang twins.
Up to this point I have washed the vehicle, clayed the vehicle, polished, then sealed.
Autobathe
XMT speed clay
Pinnacle Advanced Finishing polish
Wolfgang paint sealant 3.0
The clay bar left some small scratches which most can be polished out. I used an ample amount of lube while claying and kept kneading the clay over and over multiple times. Used a couple different pieces also.
Talked with Nick and he explained basically to just polish most of the light scratches out with the Pinnacle finishing polish. I noticed one or two isolated deeper ones which possibly are from contaminates being trapped and drug over the surface.
Im looking at a couple different products for removing moderate scratches. Ive looked at the Menzerna line but unsure which would suit me. Ive spoke with Nick about the Wolfgang and Pinnacle Advanced swirl remover but I was worried it would be a tad too aggressive. He assured me that is isnt.
I was looking at the Menzerna Intensive 1500, power finish 2500, final finish 3000, and super finish 4000 or 4500. Im totally lost on which ones are going to be the one for me. I will be using the Lake Country 5.5 flat pads and the LC 4 inch CCS pads. Any of you guys that have used these or can recommend other products would be greatly appreciated.
Here is the truck pulled out of the garage under sunlight. I have only polished with 1500 then 4500. No sealant yet.
Wow, that looks awesome!!
Those pics are before selant. I just put the Menzerna power lock on. Will take new pics tomorrow.
You might want to check out Opti Coat, it's advertised as a permanent sealant.
I want to Opti Coat my car, but Kinda want to play around with sealants, waxes, glazes for a bit lol.
Check this one out:
http://www.autogeekonline.net/forum/...ad.php?t=66009
Great truck to btw
By '03 Ram 5.9 in forum Auto Detailing 101
Last Post: 10-16-2017, 12:38 PM
By FF1350 in forum Auto Detailing 101
Last Post: 06-06-2014, 05:54 AM
By tkarns24 in forum Auto Detailing 101
Last Post: 05-23-2012, 04:58 AM
By nabisco shine in forum Auto Detailing 101
Last Post: 08-06-2010, 04:50 PM
By king air pilot in forum Auto Detailing 101
Last Post: 08-11-2008, 12:55 PM
