For Flex 3401 users ... Anyone else see this?
Is it normal? Anyone know what causes it? Should I be concerned?
Performance hasn't been affected but after every Detail it's really hot..
Re: Does the steel head on your FLEX 3401 get hot?
It is aluminum and they chose aluminum for it's great ability to dissipate heat. If it was made of steel the plastic gears would surely melt down. I have been blistered from touching the aluminum gear housing.
It does get hot but the plastic cover creates a barrier between "it" and your hand, it's designed to perform this way. If you look closely you'll see a gap between the metal housing and the plastic guard. This allows constant air flow and an aid in cooling...
