Re: Some claim an extractor is not needed for interior detailing....
If I were a pro and did more interior work (I don't really do interiors...at all...for people) I would likely get a Mytee.
The Bissell Little Green Machine works okay, though. Takes a pretty long time, but it does eventually get the job done. I used it here on a 1996 Jeep Cherokee that likely never was cleaned (it's filthy). The seat was quite nasty, and I'm sure the coke or coffee had been there since forever. Over 240k miles on it from the prior owner.
Anyway...action!
I had a defective model due to excessive leaking. Since, I returned it I haven’t found a need for one in a while. But I’m not saying it isn’t a valuable machine either—because it is.
When it did work, it worked fine and did the job.
Anyway...action!
^^ I use a similar one only I go two-handed. My process is this:
- I pre-treat with Folex or the appropriate chemical.
- Then with the Bissel I spray pure water onto the area/cushion/seat. Not a lot, just enough to dampen the fibers over top the pre-treatment.
- Then I go two-handed with the steam blasting in one hand, followed with the extractor right above it thus it's sucking out pure HOT steam, water and Folex. It's way way way better than just the bissel alone.
Uses far less water, thus seats are barely damp, yet it pulls out the nastiest stuff leaving the seat disinfected and clean. Two passes is all it takes.
I just used this process to clean our family room couch that has a lot of white on it. Worked perfectly. Like brand new having pulled off any and all oils and what not.
Post Thanks / Like - 3 Thanks, 3 Likes, 0 Dislikes
There was that steam extractor that Richy was using that I looked at for a while...then he went and bought a Mytee.
Originally Posted by WRAPT C5Z06
It would be nice to see a review on that one. That model never used to have heat, they added the heated version a year or two ago. One thing to keep in mind is the Tempo only has a 600 watt heater, and doesn't give a temperature that it gets to, while the Lite has a 1000W and the two larger ones have 1200W...those three all say "210°F max temperature"...which doesn't exactly mean they get to that temp, I guess.
If your going to get one, and use it often , and hard...go all in and get a good one with a reputable company. Check the reviews and warranty. Those cheaper units made by these small companies are for sure going to break down after a year, and those companies most likely won't even be around for long.
I have the HP 120 at the shop,I'd say temp gets every bit of 200 plus.
If I am running a continuous stream of steam the nozzle gets so hot you have to set it down a second,,plastic may have been a better option for that area.
Reliability hasn't been an issue except for one guy we had there kept over sudsing the carpets and filling the waste up with suds and water causing it overflow water and suds through motor,,,,this wiped the motor out after awhile and I had to replace it.
It was easily serviceable and only took about 20 minutes or so to swap the motors
btw mine gets used alot,,3 or 4 and sometimes 5 x a week
“I have trouble with names and faces, but I never forget a car.”
That sounds like a good process. My Bissell does heat the water it sprays, but I'm sure steam would be more effective!
By duffthebluff in forum Auto Detailing 101
Last Post: 11-09-2020, 02:27 PM
By LAKings22 in forum Auto Detailing 101
Last Post: 06-08-2015, 07:30 PM
By Bates Detailing in forum Off-Topic
Last Post: 07-08-2012, 01:20 PM
By ScubaCougr in forum Auto Detailing 101
Last Post: 05-17-2011, 07:22 PM
