Results 1 to 6 of 6
    Feb 2016
    Bay Area, CA
    45
    Swirl Finding Background
    Is there an ideal background/background color to be at when spotting for swirls with your light? I will be detailing under a canopy with enclosed sidewalls, the sidewalls are a blue color. I can put a different color sidewall on it if necessary.
    Super Member VISITOR's Avatar
    May 2007
    9,730
    Feb 2016
    Bay Area, CA
    45
    Re: Swirl Finding Background
    I actually built that DIY light setup. My question maybe a bit confusing but for example, if I am in the garage, my background would most likely be cement/gray walls or even the white dry wall.
    Super Member lawrenceSA's Avatar
    Feb 2012
    Durban - South Africa
    1,713
    I have always found that having the room you are working in as dark as possible will help show up swirls, so I tend to turn all the lights off when inspecting the paint. Not sure how this factors into the actual wall colors?
    Super Member Joe@NextLevelDetail's Avatar
    Jun 2015
    1,929
    Quote Originally Posted by lawrenceSA View Post
    I agree with Lawrence, When a customer comes in for a consultation, And I really want to show them how bad their car really is. I turn off the overhead lights in the shop and place my 2 Led Lights on the panel that I am going to be performing a test spot on.
    This shows the customer the quality of your work. All while showing them how bad their car really is.
    I typically only use this method when a person is educated and knows about swirl marks and scratches and actually wants them removed.
    Feb 2016
    Bay Area, CA
    45
    I don't have a garage so I will be polishing under a canopy that has sidewalls, like this: https://s7d2.scene7.com/is/image/dks...NODR_Royal_is/
    Hopefully my Scangrip Sunmatch and the DIY lighting setup linked above by VISITOR will show the swirls.
  1. Help me choose a Flash Light for swirl Finding??
    By chrisg8p in forum Auto Detailing 101
    Last Post: 12-15-2020, 04:30 PM
  2. New home...new background...new product!
    By Klasse Act in forum Off-Topic
    Last Post: 07-01-2020, 07:41 AM
  3. Intro, Background, Waterspots
    By echardcore in forum Auto Detailing 101
    Last Post: 07-23-2017, 12:09 PM
  4. Check out this background
    By hoyt66 in forum Off-Topic
    Last Post: 05-27-2013, 01:00 PM
  5. Detailing Background/Info
    By HealthyCivic in forum Auto Detailing 101
    Last Post: 09-23-2009, 05:13 PM
