Thank you. Just a simple article for a process that should be kept simple but effective.
Thanks Marc. Again, just a simple process for maintaining a coated car. Currently in the Wolfgang line there's no dedicated or specific spray-and-wipe maintenance product that also offers a synergistic chemical compatibility like there is in the Pinnacle Black Label line.
I think this is the weak link in all coating lines in that if the idea is to NOT apply something over the coating that defeats the features and benefits of the coating, then besides washing and thoroughly rinsing there's not much else you can use.
In the past I used the Pinnacle Black Label Surface Coating on the wife's car and then after washing it I would use the PBL Detailer to remove any of the fine water spots that are left on the paint after drying and then either re-apply the Surface Coating or the Booster. Both restored that "Just Coated Look" that I really like our cars to have and also maintained the easy to wash, easy to dry and self-cleaning effect that makes me use a coating in the first place.
Great question.
Marc already did a good job of answering you but I'll add my 2 cents...
Years ago I learned about the least invasive way to dry your car from some guy that caused a huge wax war with the Zaino fans when he tested Zaino against Meguiar's Gold Class Wax on his black Porsche. (that's what I remember), the Zaino Fans took him to task and I think after some time he came around to seeing the Zaino light.
Besides the wax wars incident, I believe it was this guy that shared his technique for drying his black Porsche, which was to pat dry the car instead of wiping the paint. The big picture being that IF a person wanted to do everything they could do to be as careful as possible so as to not re-instill swirls and scratches into otherwise flawless paint then patting dry was a safer option than wiping dry.
As to your point, if the car is clean and the drying towel is clean and soft why would it matter if you patted the paint or wiped the paint? I think both are safe I just think one is more safe than the other.
If you really want to DRILL DOWN DEEP (and I can drill down as deep and usually deeper than anyone), when you wipe paint you create more friction against the surface than when you pat paint. So lets play my forum game for AR People of putting things in extremes.
Question: Does wiping paint
add more protection to the paint?
Answer: No.
Question: What's the opposite of the word
add?
Answer: Subtract.
So wiping paint is more aggressive to anything applied to the paint to protect it and make it look good than patting paint. Although coatings form a stronger bond to paint than car waxes and synthetic paint sealants, wiping them taken to the extreme would still be more aggressive than patting them.
Besides the topic or removing via wiping via physical contact with some sort of drying media, if you want to go even deeper lets talk about gloss and shine. Again, lets use the forum game for AR people of putting things into extremes.
add more gloss and shine?
Answer: No.
add?
Answer: Subtract.
So if a person has a freshly coated car and they are in absolute love with the high level of gloss and shine, i.e. the glassy look, then patting the paint dry will do more to preserve the high gloss finish than repeated wiping of the surface.
Of course for those of us that do "something to our car's paint often enough that longevity of any measure is a moot point then wiping is perfectly okay.
I'm not sure I can go any deeper than this but I think this is deeper than most people can go or think.
Patting takes more time and also takes more drying towels. One product that actually works really well for this is the Guzzler HD Waffle Weave Drying Towel. It has the same soft microfiber waffle weave outer material but also includes a water absorbing foam inter-core. So you place this towel flat on a surface, allow the water to migrate into the microfiber and then into the foam inter-core and presto... the water is gone and the surface is dry without wiping.
6 Pack Cobra Guzzler HD Waffle Weave Drying Towels, 16 x 24 inches
