Active member
- Dec 5, 2022
- 51,004
- 8
Almost as fast as a rotary buffer but a lot safer - What is it?
What is almost as fast as a rotary buffer but a lot safer to use?
The Flex 3401 with a wool pad!
So you want to do some major correction work huh? Remove years of neglect that has left millions of swirls, scratches, oxidation and water spots in the paint? Or, you're working on a gel-coat boat and you need to remove years of heavy oxidation?
Then get yourself a Flex 3401 and a Lake Country 7.5" Electrified Wool Polishing pad. No matter how hard you press against the Flex 3401 because it's a gear-driven orbital polisher there's nothing you can do that will stop the pad from both rotating and oscillating and that means you can do what I call,
Power through a detail
Then to increase the cutting speed and power, get a wool pad for your FLEX 3401.
Even though they use the word polishing to describe the 7.5" Electrified White Sheepskin Final Polishing Pad - don't be fooled, it still cuts like a son-of-a-gun because it's a WOOL pad.
Fibers are a form of abrasive be they wool cutting or wool polishing pads.
Electrified?
The word electrified means Lake Country has taken the extra step to electrify the wool which removes the natural sharp barbs found in wool creating a pad that cuts fast but finishes with less scouring of the paint. This is a real benefit when buffing thin, scratch-sensitive clearcoat finishes.
The FLEX 3401 with a wool pad
Before
After
Faster than any free spinning dual action polisher no matter what the shape of the panel or condition of the paint and safer than a rotary buffer.
On Autogeek.com
FLEX 3401 Dual Action Orbital Polisher
Get my how-to book,
How to use the Flex XC3401 VRG Dual Action Orbital Polisher
Learn how to detail faster while keeping quality high!
Electrified?
Before
After
On Autogeek.com
Get my how-to book,
