Re: getting a order together need help
Originally Posted by wildwilly1
I tried the optimum microfiber and fg400 didn't touch the water spot etching. I pretty much realize that I will not be able to completely remove them but would like to make them better also what white and green pads from lake country or where
What technique were you using with that combo?
-Speed Setting
-Arm Speed
-Downward Pressure
-Number of Passes
speed 6 , slow arm speed, moderate pressure, probably 14x14 work spot
Originally Posted by allenk4
This is spot on! Definitely try orange with FG400 first! It will more than likely remove the water spots. From there hit it with SF4000 and enjoy your clear and super glossy paint!
the orange ccs pad right. I thought the microfiber optimum had more cut im confused ?
It may or may not for you on a PC.
I think Optimum offers two different thicknesses. With a PC, you want the thin ones.
Optimum Polymer Technologies: Advanced Polymer Technology is in every Optimum Car Care Product. opt car care, optimum car wax, optimum car wash,
I have only used microfiber pads on a limited basis with an old 7424. I found that unless I cleaned them after every section pass, I did not get good cut at all. I used a pad brush, but many on the Forum suggest that compressed air is more effective.
I did use the thin ones and did clean them with a brush every pass
I will order the orange pads to try first but I will also order either the thin lc purple wool or the meguirs micro fiber which one do you guys like better of the two
I used the Purple pads but found that I like these better. I was using them to remove 1500 and 3000 grit sanding marks at work however. So not sure if they would be to aggressive or not.
http://www.autogeek.net/lc-hyb-150bw.html
aren't those for a rotary
well here is what I ordered
#1orange ccs pad 5.5inch
#2white ccs pad 5.5inch
#3lake country thin purple wool pad 5.5 inch
#4chemical guys ez crème glaze
#5blackfire wet diamond paint sealant
#6collinite 845
i already have enough menz fg400.will use the meguirs 205 for polishing after the 400 after everything is corrected and i am satisfied with it i will use ez crème glaze then blackfire wetdiamond then collinite 845. what do you guys think good or bad plan
By thebouncer in forum Auto Detailing 101
Last Post: 04-28-2017, 07:37 AM
By seanzh12 in forum Customer Comments
Last Post: 01-25-2017, 08:15 AM
By Spiney in forum Auto Detailing 101
Last Post: 12-26-2011, 07:56 AM
By kenzo42 in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 06-29-2009, 08:41 AM
By MoparAddict in forum Auto Detailing 101
Last Post: 08-31-2007, 12:57 AM
