Recommondations on Foam Pad 8"
Foam / Wool Pads & Accessories for Rotary/Circular Polishers
Hey everyone. I recently got a Mikta 9227c Rotary Buffer which I have some exp on and I will be practicing on some junk body panels to hone my craft. I expect to be using Meguiar's products such as M150/M205 combo and M80/M83.
Basically I have a 7" Back plate (loop and hook) and my understanding I will be looking at 8" Pads.
I see there is Lake Country and Meguairs I see, is there a preference on which type??
Also with the above listed chemicals any certain pad/chem combos you can think of.
Looking at correcting
RDS
Etching
Swirls
Acid Rain
So on and so forth!
Re: Recommondations on Foam Pad 8"
These are the ones you want - CCS 8.5 inch Foam Pads, Lake Country 8.5 inch ccs pads, lake country ccs foam pads, rotary ccs foam pads, ccs polishing pads
I'd get a 6 pack. 2 orange, 2 white, 1 gray, 1 red. This will be a good kit to get you started. Might also want to get a couple wool cutting pads as well for really bad stuff.
Originally Posted by matt@autogeek.net
perfect, thanks. I do have 2 wool pads that came with the kit. I'll use those up first before rebuying be def thanks for the info.
Any diff or thoughts on the CCS pads vs Smart Pads.
CCS are Smart Pads.
Opps, my mistake, I was looking at the listing wrong. I saw Komperssor but those were 7" and and the 6 pack were the same pads. Perfect, thanks for the clarification!
Gotcha. Kompressors will not fit your backing plate, unfortunately. If you purchase a 6" LC place, the 7" Kompressors will fit.
Kompressor any good, aside from the fact smaller pad allows for tighter areas?
Yes, they're great, especially with a rotary. Definitely worth trying as they are very stable to work with and the rounded edges are pretty nice.
Ok cool definitly something to check out when I have a chance. Thanks! If anyone else has input on chem/pad choices let me know.
Sounds like I would combine on a heavily swirled car some M105 and a Orange pad, test spot it and do a pass, then inspect. If good, then move on to M105 and a White Pad w/ M205. The follow up with my normal glaze/sealant/wax process?
I'd probably finish with M205/gray. On a lot of paints, M205/white via rotary may leave holograms. But experiment with different combos and see what works best - that's the whole point of having a variety of pads.
By stevehecht in forum Auto Detailing 101
Last Post: 03-29-2020, 03:21 PM
By mightypudge in forum Auto Detailing 101
Last Post: 06-17-2018, 07:12 PM
By Mirror Detailing in forum Auto Detailing 101
Last Post: 06-10-2010, 02:27 PM
By turbos17 in forum Auto Detailing 101
Last Post: 01-15-2010, 12:44 AM
