Foam Pad Size for Meguiar's W67DA Backing Plate?
Hi Everyone,
I plan to purchase a Griot's 6" and the Meguiar's Microfiber Correcting System Pad kit to do a quick polish on my car before I seal and wax it. The kit comes with 2 MF cutting and 2 MF finishing pads and a W67DA 5" backing plate. I would like to get a couple foam finishing pads to use when applying the sealant and wax, but I am confused about what foam pads will work the W67DA backing plate. My car has a lot of curves, so I would like to use the 5" BP instead of the 6.5" Griot's BP the GG6 comes with.
Which pads & what size would be best for the W67DA BP?
I was looking at the Meguiar's DFF5 5" finishing pad, but I think 5.5" might be the more appropriate size. If I use a non-Meguiar's pad, will there be an issues between the hook and loop?
Thanks,
-Rick
Re: Foam Pad Size for Meguiar's W67DA Backing Plate?
Either a 5" or 5.5" pad will fit that backing plate. By the way the Meguiar's foam discs are nice pads. You will not have any issues using any either pads with it.
Thanks for the replies! I am still sorting through which products to get, but it is great to know the Meguiar's backing plate will work with other pads!
By segdoh49 in forum Ask your detailing questions!
Last Post: 08-09-2016, 04:05 PM
By vandervortadam in forum Wool & Foam Buffing Pads
Last Post: 05-25-2014, 02:20 PM
By Justin at Final Inspection in forum Rotary Buffers
Last Post: 04-30-2014, 10:21 AM
By shagnat in forum Auto Detailing 101
Last Post: 01-02-2014, 06:16 PM
By frank10 in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 09-06-2010, 06:48 AM
25 | 26 | 27 | 28 | 29 |
