Fast finishing pad
Does anyone like using a microfiber fast finishing pad (griots) for polishing? And if its brand new should i prime it with product like i would a new foam pad?
Re: Fast finishing pad
I use the boss microfiber cutting pad, not sure about finishing microfiber not sure if they have one?
M105/boss mf did awesome results with almost lsp on a white truck i did.
Haven't tryd the megs finishing microfiber yet tho.
I prime every pad regardless of material.
I've used the fast finishing pad with their Complete Compound. Took me a little getting used to, but I've had good results. I prime the whole surface, then just make sure to check in on it standing the nap up when changing sections.
Agreed
Thanks guys. I hadn't heard much about the microfiber finishing pad. I found some pads for cheap so I figured I'd grab a couple and try them out before I ordered a few six-packs of assorted off autogeek.
FWIW, here's a junkyard bumper before/after of my most recent go around with the fast finishing pad and complete compound.
John
That came out good. So did you use that combo as a one step process or would you still polish that after? And would you not use that pad to do final polish, mostly compounding?
Only use a MF pad for finishing when the paint is HARD.
The complete compound is just for correction. In this case I followed it with GG One Step Sealant (which I think counts as an AIO) using an orange polishing pad to match what was on the rest of the car.
By DUBL0WS6 in forum Wool & Foam Buffing Pads
Last Post: 09-12-2020, 03:15 PM
By Joe@NextLevelDetail in forum Product Reviews
Last Post: 03-13-2017, 12:15 PM
By samsumon in forum Auto Detailing 101
Last Post: 07-20-2016, 07:27 PM
Last Post: 06-16-2016, 09:38 AM
By Justin at Final Inspection in forum Product Reviews
Last Post: 04-01-2016, 07:48 AM
