» Detailing Classes
Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 45
  1. #31
    Senior Member conman1395's Avatar
    Nov 2013
    Kansas City, KS
    1,617
    Re: Lake Country ThinPro Foam Buffing Pads exclusively at Autogeek
    From the description it looks like these pads are much firmer. It would be nice to have a firm black pad. I almost never use black pads any more because they're so soft that they morph too much when using them and don't finish well. How does the Lake Country Black compare to the Meguiar's Black in terms of density/firmness?
  2. #32
    In time out
    Sep 2014
    Johannesburg,South Africa
    1,631
    Quote Originally Posted by NextLevelDtail View Post
    Quite the opposite the thin pads stall more then thick pads. On contoured edges and curves. That is why griots made that innerflex pad to make the pad thicker to adjust to the curved panel.
    The innerflex pad works however at high speeds its junk it shreds.
    Thats why i just use LC pads the thick ones for those areas and it spins and rotates fine.
    That is on a da of course the flex will have no problem no matter what you stick on it
    It is my understanding that a thinner hence lighter pad has less energy being lost and will be more likely to maintain rotation. Either way I can't wait to get my grubby lil paws on these and the Buff and Shine Low-Pro's and compare the grey vs green in outright cut. Whichever has more cut, thats the ones I will be reordering on a regular basis.
  3. #33
    In time out
    Sep 2014
    1,631
    Quote Originally Posted by conman1395 View Post
    All Lake Country black pads are soft finishing pads but compared to other brands they firmer and to me the reason they finish better: Soft+Firm makes for nice jeweling and uniform results.
  4. #34
    Senior Member Joe@NextLevelDetail's Avatar
    Jun 2015
    1,929
    Quote Originally Posted by Zubair View Post
    They help increase rotation and correction on flat panels or little concave areas.
    On a curved edge . They struggle because the pad does not have enough foam to mold and shape into that contour, all thin pads do.
    Just keep some LC pads when you want to use the da Or just use the flex
  5. #35
    Jul 2013
    Apex, NC
    1,283
    How are the Rupes and GG long throw polishers not free spinning spindle machines?
  6. #36
    Nov 2009
    Pasadena, CA
    12,602
    Quote Originally Posted by DBAILEY View Post
    They are.
    '03 Corvette Z06
  7. #37
    Jan 2015
    are these suitable for the GG Boss g15, or are there better options(other than the ones made by GG)
    TIA
  8. #38
    Senior Member LSNAutoDetailing's Avatar
    Jun 2014
    Chandler, AZ
    3,277
    Quote Originally Posted by drabon74 View Post
    TIA
    "Each pad utilizes a new foam composition that promises to withstand the rigorous abuse of long-throw orbital polishers, like the Rupes LHR 15 and 21ES and Griotís Garage Boss G15 and G21 polishers. A super strong adhesive used for attaching the backing material to the foam pad provides a rugged attachment point that is virtually indestructible, even after extended polishing sessions."
    ThinPro pads are available in 5.5" diameter and 6.5" pads.
    On Autogeek.com
    Lake Country ThinPro Foam Pad System 5.5 inch
    Lake Country ThinPro Foam Pad System 6.5 inch
    Also known as Paul G
  9. #39
    Feb 2013
    San Antonio, Tx
    114
    I am curious, would these require more frequently cleaning since they are so much thinner?
  10. #40
    Member
    Dec 2010
    91
    Quote Originally Posted by timsatx View Post
    IMO, the surface of the pad does all the work so in terms of cleaning, shouldnt makes any difference.
    The size are really optimal with DA. If they punch a 1.5cm hole in the center, my guess is the pad may works even better.
  1. Lake Country ThinPro Foam Pad System
    By VISITOR in forum Wool & Foam Buffing Pads
    Last Post: 02-03-2016, 11:40 AM
  2. Lake Country ThinPro Foam Pads??
    By ski2 in forum New Car Care Products
    Last Post: 11-15-2015, 04:32 PM
  3. Autogeek Commercial - Lake Country Buffing Pads
    By Mike Phillips in forum Autogeek on Velocity Channel TV
    Last Post: 05-16-2011, 04:23 PM
  4. The Kompressor Foam Buffing Pads by Lake Country
    By Wendell Jarvis in forum Auto Detailing 101
    Last Post: 02-17-2009, 09:53 AM
  5. Lake Country CCS Foam Buffing Pads.
    By supercharged in forum Auto Detailing 101
    Last Post: 12-26-2006, 12:22 PM
Members who have read this thread: 39
» September 2020
3031 1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 123
