Re: Confused on cut of Hybrid pad colors??
Originally Posted by Zubair
I use the Rupes Blue mf and the Optimum Cutting mf pads. Tried the FG400 on both and it breaks down already when spreading it out and gums up the fibres. I prefer using FG400 with wool if I need more cut over foam. Rupes Zephir or Quarz work better on mf pads than Menzerna.
Haven't used the Opti MF pads yet but I don't like the Rupes MF at all. Guess I'll have to try the Rupes polishes with MF. I tend to stick with Rupes foam when I'm using the Rupes Polishes. Haven't had the issue you're talking about with the B&S MF pads and FG400. Actually quite often I go straight to LSP after that combo because it provides the results the customers ask for and pay for. Also I blow out the MF with an air gun in between each section and swap out every panel to prevent heat buildup.
Finishing Touch Auto (Stayton, OR)
Ryan Hendricks (Owner) 503-602-8483
FTA Website
By VickMacky in forum Wool & Foam Buffing Pads
Last Post: 09-28-2017, 08:49 PM
By lane5515 in forum Wool & Foam Buffing Pads
Last Post: 05-21-2017, 10:49 AM
By itay in forum Wool & Foam Buffing Pads
Last Post: 01-01-2013, 04:54 PM
By DP 08 GXP in forum Wool & Foam Buffing Pads
Last Post: 11-06-2012, 12:38 AM
By mike matchlat in forum Off-Topic
Last Post: 07-02-2010, 06:45 PM
