Page 4 of 4 FirstFirst 1234
Results 31 to 35 of 35
  1. #31
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,016
    Re: LC hydro vs LC waffle pads
    Quote Originally Posted by Mike Honcho View Post
    Any update?
    Hi Mike. Yes, I happy to report that none of the Hydrotech pads failed on me. I had two of the Cyan start to degrade. (Keep in mind that I did some testing on them.)
    Here's why:
    As we polish paint, the residue needs somewhere to go. On open cell pads, the residue has a bit of an escape route inside the open cell network. With the Hydrotech, the residue can rupture the closed cells of the pad, causing them to wear pre maturely. This is hastened when:
    1. Excessive pressure is used, which forces the residue up into the closed cells. Also creates heat.
    2. Excessive heat caused by high speeds and high pressure.
    3. Excessive product. This over saturates the pad, throwing the pad/product ratios off. Once the center of the pad is over saturated, it runs the risk of collapse due to heat.
    General usage will wear any pad out naturally, but expect the hydrotech pads to indicate wear earlier than a comparable flat, or ccs. Note that even as a pad wears, it isn't useless. I used to use my old burgundy megs pads on a rotary long after they started to shred up. I don't know where the idea surfaced that pads need to look brand new until we decide to toss them.
  2. #32
    Super Member Mike Honcho's Avatar
    Apr 2015
    Atlanta
    1,264
    Thanks for the update!
    Mike Honcho
  3. #33
    May 2013
    Rochester Hills, Mi
    6,016
    My pleasure!
  4. #34
    Newbie Member farhan3108's Avatar
    Sep 2015
    hi everyone.. can anyone help me in this .. i am new in detailing service.. which pad is better ..Lake Country HD Orbital Foam Pads or Lake Country CCS pad
  5. #35
    In time out
    Sep 2014
    Johannesburg,South Africa
    1,631
    Quote Originally Posted by farhan3108 View Post
    On what machine?
  1. Waffle vs flat polishih pads
    By Charlieboy1 in forum Ask your detailing questions!
    Last Post: 04-11-2017, 09:13 AM
  2. Lake country hydro tech flat pads. Pads are ripping on my makita
    By Ncs0816 in forum Wool & Foam Buffing Pads
    Last Post: 10-04-2013, 08:38 PM
  3. Lake Country Waffle pads
    By Mike@DedicatedPerfection in forum Wool & Foam Buffing Pads
    Last Post: 06-26-2012, 01:52 PM
  4. Giveaway! Lake Country Waffle Pro Foam Pads
    Last Post: 06-02-2012, 03:41 AM
  5. waffle pads vs flat pads
    By Mike9825 in forum Auto Detailing 101
    Last Post: 07-29-2007, 08:01 AM
