Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    Super Member CarolinasFinestDetailing's Avatar
    May 2011
    Charlotte, NC
    1,556
    Re: Meguiars da microfiber pads
    Faster? You could use a higher cut compound if need be, and/or Xtra cut pads for bad imperfections.
    As for maneuvering, get a 3" backing plate and accompanying 3" MF pads.
    Carolina`s Finest Detailing - Charlotte areas preferred CQuartz Finest Reserve & GTECHNIQ Crystal Serum Ultra coating center. STEK/Suntek PPF
    www.Carolinasfinestdetailing.me
  2. #22
    Junior Member RMCY's Avatar
    Nov 2014
    Brazil
    35
    Quote Originally Posted by Sicktred08fsi View Post
    Thanks for the feedback.
  3. #23
    Nov 2014
    Brazil
    35
    Meguiars recomends using their backing plate based on hook and loop compatibility. Does any Megs bp for 3" MF pads fit on the Rupes mini? Does Rupes BP have issues with heating up with megs MF pads? I'm planning on buying this Rupes lhr75e and I love the MF pads for cutting.
  4. #24
    Super Member Woob's Avatar
    Jul 2006
    Cary, Raleigh, North Carolina
    566
    Quote Originally Posted by RMCY View Post
    Believe some people have switched to the Metabo 3inch backing plate (Kevin Brown carries/recommends it). The LHR75E does mad things with its throw, so I'd just rotate pads and be careful. Pretty sure the Rupes pads would hold up the best.
    Megs does have a 3inch interface/H&L system, but I'd stick with the stock Rupes or Metabo setup.
  5. #25
    Nov 2014
    Brazil
    35
    Thanks a lot.
  1. Thoughts on Meguiars Microfiber POLISHING pads?
    By jconley30 in forum Wool & Foam Buffing Pads
    Last Post: 11-20-2017, 05:27 PM
  2. Meguiars MT300 and microfiber pads
    By Jhold87 in forum Auto Detailing 101
    Last Post: 03-29-2016, 01:07 PM
  3. Meguiars Microfiber Cutting Pads
    By Coppertop80 in forum Ask your detailing questions!
    Last Post: 05-05-2015, 11:33 PM
  4. Duetto and the Meguiars microfiber system, new foam pads
    By Goleafsgo in forum RUPES BigFoot Oribital Polishers
    Last Post: 04-01-2015, 12:14 PM
  5. What Happened? Meguiars Microfiber vs Rupes Foam Pads
    By dan45hk in forum Ask your detailing questions!
    Last Post: 05-29-2014, 07:39 AM
