Pad lifespan
My question is if a pad still looks to be fine, and is cleaned on a regular basis, does the ability to cut or polish wear out?
Re: Pad lifespan
Question has been here a while - I'd like to know as well. The pad cleaner i'm using is great and the pads look like new. What is the typical lifespan of a pad? Do LC Hydros last longer?
Reason: spelling
Re: Pad lifespan
In my experience if it works then it's working. Foam is foam no matter how much of it has fallen/worn off. As in if you cut the foam in half both pieces would still work.
So use then until they don't.
I like to replace mine when they look bad. I don't want to cause any damage with a bad pad so $12 for a new pad every once in a while is cheaper then guessing if a pad isn't good and screwing up a car with it. I've never screwed up a car with an older pad but never say never. So I err on the side of caution and replace then.
Re: Pad lifespan
In general closed cell foam like the Hydrotech would not last as long as open cell foam like LC flats, due to tensile strength.
By MacS4 in forum Ask your detailing questions!
Last Post: 09-13-2017, 03:35 PM
By Desertnate in forum Auto Detailing 101
Last Post: 08-12-2015, 04:15 PM
By AustrianOak82 in forum Auto Detailing 101
Last Post: 07-22-2015, 06:01 AM
By gohandbz8 in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 06-12-2007, 05:55 PM
By 06CivicSi in forum Auto Detailing 101
Last Post: 09-14-2006, 08:04 PM
