Re: Smaller DA pads for Makita circuar ??
Originally Posted by Rsurfer
Try the 3" pads, they are so cute.
You kill me .
Originally Posted by rsurfer
try the 3" pads, they are so cute.im the man
lol!
I assuming that you need to speed up the buffer when you go down to smaller pads? What to you 'generally' run a 5.5" pad at? I've been running them at 1500-1900 rpm, but was thinking that I might want to speed them up in order to get the outer edge up to the speed of a 6.5" ot 8" pad spinning at 1500 rpm? Just looking for some general guideline as I know each application will be different.
Check out Pakshak
Here's a source...
This is a really nice backing plate...
Heavy Duty 5 Inch Rotary Backing Plate, circular polisher backing plate, backing pad
Here's a 2 3/4" backing plate and it works really nice for the Griot's Garage 3" foam polishing pad...
2-3/4 inch Hook & Loop Rotary Backing Plate
Griot's Garage 3 Inch Orange Polishing Foam Pads, Griots foam polishing pads, Griots orange foam pads
Here's a video that talks about the Flex 3403 but it also shows a variety of small pads that can be used with any rotary buffer.
[ame=http://www.youtube.com/watch?v=hVm_IJuXNc0]YouTube - Mike Phillips Showcases the Flex 3403 Lightweight Rotary Buffer[/video]
Originally Posted by 1sickss
Im about to order the Makita circular buffer, just wondering if it is ok to use some of the smaller DA pads with the circular, ive noticed that some say for DA use, while the bigger pads like the 7 - 8.5 in pads are for the circular buffers....Does it matter ?
Check out this
Pictures + Video of 1932 Ford Highboy Extreme Makeover
The Flex 3403 with a Griot's Garage 3" Polishing pad comes in so handy for working on thin panels and there were plenty of thin panels on this car to buff out.
Being very careful, it was possible to run the thin, Flex 3403 in-between the side of the grill and the headlight bucket.
We could even work on the hairpins for the front suspension...
Top of the frame rail needs a little amping up of the gloss...
The major panels were buffed using a Makita 9227C Rotary Buffer using a double sided wool cutting pad and XMT Heavy Duty Rubbing Compound. After this step a foam polishing pad with Wolfgang Total Swirl Remover was used to remove the compounding swirls left by the XMT #4 Heavy Duty Rubbing Compound. Note that XMT #4 Heavy Duty Rubbing Compound is a very, very aggressive compound and should only be used for serious correction work.
Last Post: 08-28-2020, 05:29 PM
By mwoywod in forum Auto Detailing 101
Last Post: 12-14-2016, 08:16 PM
By BigHead in forum Wool & Foam Buffing Pads
Last Post: 03-04-2015, 09:01 AM
By theamcguy in forum Auto Detailing Tools and Accessories
Last Post: 07-01-2014, 07:41 PM
By flyinion in forum Auto Detailing 101
Last Post: 07-19-2012, 08:28 AM
