» Detailing Classes
Page 4 of 4 FirstFirst 1234
Results 31 to 39 of 39
  1. #31
    Senior Member PaulMys's Avatar
    Jan 2014
    L.I. NY
    7,758
    Re: Center cooling hole in foam pads
    Swap out your pads more often (5-6) per color.
    ^^^ This ^^^
    I use up to 20 pads on my Ram.
    *Keeps them from overheating.
    *Keeps them from getting gummed up, and a clean pad performs much better.
    *Makes them way easier to clean.
    *Extends pad life.
  2. Likes Rsurfer liked this post
  3. #32
    Member Icarus's Avatar
    Oct 2019
    Ontario, Canada eh!
    89
    I've got 4 of each, and use a brush and cloth to make sure they don't get saturated now. I couldn't afford 20 of each pad lol... I was taking my time and rotating them every couple panels or after the hood or back end. I was checking for heat with my hand every once in while but they still got hot.
    I think taking them right off once in a while and checking for heat is better then checking from the side that's not making the heat (backing plate.) Think an extra washer on the backing plate would help any?
    Ϣr
  4. #33
    Jan 2014
    L.I. NY
    7,758
    Quote Originally Posted by Icarus View Post
    Keep an eye out for sales, then stock up when they hit.
    Are you using a vented backing plate?
    **EDIT**. I just read your previous posts.
    If you are having problems with the centers heating up, I would use more pads, try out the BOSS pads (with the center hole), or maybe refine your techniques/pad & product combos.
    I have worked some pads pretty hard in certain situations, and I have never had them be so hot that I was worried about them.
  5. #34
    Oct 2019
    Ontario, Canada eh!
    89
    I'm using the G9 backing plate which is the same as the BOSS one (other then the new fanned one.) I'm sure its mostly my technique still (bit to much product, getting a bit ahead of myself, etc.) I still want to put a hole in a couple and see how much of a difference it makes, but the temps are going down fast here
    Ϣr
  6. #35
    Jan 2014
    L.I. NY
    7,758
    I'm using the G9 backing plate which is the same as the BOSS one. I'm sure its mostly my technique still (bit to much product, getting a bit ahead of myself, etc.) I still want to put a hole in a couple and see how much of a difference it makes, but the temps are going down fast here
    More time to save up over the winter for some BOSS pads.........
  7. Likes Icarus liked this post
  8. #36
    Oct 2019
    Ontario, Canada eh!
    89
    Yes, I think I might save up for a 5" G9 backing plate and save this 6" stuff for the larger flatter vehicles. I want to try out some Sonax compounds and polishes too, but this stuff is so pricey here
    Ϣr
  9. #37
    Senior Member psnt1ol's Avatar
    Aug 2012
    San Francisco
    529
    The Black Friday sale and 12 days of Christmas Sale on Autogeek generally are pretty sweet. I will be using up all my Autogeek points that I have been saving in 2020 this holiday season.
  10. #38
    Oct 2019
    Ontario, Canada eh!
    89
    Quote Originally Posted by psnt1ol View Post
    Shipping rates to Canada start at $41.99 USD and go up from there. We also have to pay exchange rate and import tariffs... It sucks to ship across the border now... I'll have to look for sales up here and IF stuff is in stock
    Ϣr
  11. #39
    Jan 2014
    L.I. NY
    7,758
    Too bad the northern border isn't quite as porous as the southern border. You might be able to pay a young entrepreneur to deliver your pads at a cheaper rate.
    Did I just say that out loud?
  1. Cutting center cooling chamber in Megs Microfiber pads.
    By mwoywod in forum Auto Detailing 101
    Last Post: 11-13-2020, 10:15 PM
  2. Replies: 38
    Last Post: 03-11-2019, 07:52 AM
  3. B&S Microfiber Pad without hole in center?
    By FinishingTouchA in forum Auto Detailing 101
    Last Post: 09-15-2015, 11:41 PM
  4. Pads? Hybrid vs Foam vs Hex logic foam vs Microfiber???
    By Socalsteve in forum Ask Mike Phillips your detailing questions!
    Last Post: 04-25-2014, 11:43 AM
  5. Cooling your garage
    By pokey in forum Auto and Garage Accessories
    Last Post: 06-30-2010, 10:14 AM
Members who have read this thread: 47
» December 2020
2930 1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 31 12
