» Detailing Classes
Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    Sep 2017
    Sweden
    2,868
    Re: Center cooling hole in foam pads
    Quote Originally Posted by Icarus View Post
    I went over a few spots again with compound using the tricks more carefully SWETM and others have given, and its working much better now! I was def using to much compound and over working the pads some. Thanks Tony and everyone!
    Awesome to hear that you where able to dial it in more!
    You are welcome and I like how so many are so helpfull. Next time it can be any of us that needs some help.
    / Tony
  2. #22
    Member Icarus's Avatar
    Oct 2019
    Ontario, Canada eh!
    50
    Car turned out pretty nice, even though there was the paint blown in on a few spots I could see the outline of on the DS :/ (see my other thread.) I followed some of the advice from SWETM and others and used speed 4 instead of 5, and not as much compound, and it turned out much better then using a bit more compound and speed 5 (and rushing at times lol). I did this for the polish too (speed 4, only primed them with about 4 drops, then 3 from then on, and did a bit smaller areas.) With the polish the pads didn't seem to get anywhere near as hot as the compounding and always seem cool/fine to the touch.
    It turned out pretty good for my first actual correction, polish and wax (I've polished a few cars in the past and waxed, but nothing like this, so was an interesting learning experience.)
    The only topper was as I literally finished and walked into my garage, it started to rain and has been raining off/on since :/ (just the way my luck usually goes!) lol...
    Ϣr
  3. Thanks Diner thanked for this post
    Likes SWETM liked this post
  4. #23
    Sep 2017
    Sweden
    2,868
    When you just have gotten the test spots dialed in and you have your combos. It's such of joy polishing the whole car. That with getting the right amount of compound and polish on the pad and how it reacts on the paint can be so different. Also when you are on the low with the amount of pads you have available when you going to be polishing the whole car it's even more important. To be able to stretch the pads use longer by even by little. Saves the pads to get more durability out from them. Of course there are other ways to do this too. But then it's very important to have more pads at hand. To get the most even results and also being able to use the pads more than just a couple of times.
    The more you do it the more you understand it and can tweak what you are doing on the fly. It's just something that you get by polishing and is almost impossible to learn by reading about. Then we can look at it in different ways and have different tools to do it. But as long as we selfs gets satisfied is all that counts. Now it's the thing to use tools and equipments and chemical products and methods to have the paint looking awesome as long as possible. And so a polish step is enough every year or every other year. So you save as much of the clearcoat as possible. That's not so easy to be doing as it's something that you do over such a long time. Also to find something that you like doing so it don't takes forever to wash a car LOL.
    Great work and awesome to see your follow up of your experience. Thank you for that.
    / Tony
  5. #24
    Senior Member Mgavin1985's Avatar
    Nov 2017
    423
    Only if your lonely.
  6. Likes Jayfro, rangerbay liked this post
  1. Replies: 38
    Last Post: 03-11-2019, 07:52 AM
  2. Cutting center cooling chamber in Megs Microfiber pads.
    By mwoywod in forum Auto Detailing 101
    Last Post: 01-14-2018, 08:27 PM
  3. B&S Microfiber Pad without hole in center?
    By FinishingTouchA in forum Auto Detailing 101
    Last Post: 09-15-2015, 11:41 PM
  4. Pads? Hybrid vs Foam vs Hex logic foam vs Microfiber???
    By Socalsteve in forum Ask Mike Phillips your detailing questions!
    Last Post: 04-25-2014, 11:43 AM
  5. Cooling your garage
    By pokey in forum Auto and Garage Accessories
    Last Post: 06-30-2010, 10:14 AM
Members who have read this thread: 88
» December 2019
1 2 3 4 5 6 7
8 9 10 11 12 13 14
15 16 17 18 19 20 21
22 23 24 25 26 27 28
29 30 31 1234
