» Detailing Classes
Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. #21
    Member Strip Poker 388's Avatar
    Jan 2010
    Ms.
    38
    Question Re: Lake Country Force Hybrid or Lake Country Hybrid Power Finish pads for FLEX 3401?
    Is there a disadvantage with the pad having the hole? Catching a edge on something? Thats Using the 6.5 inch Lake Country Force Hybrid pad w/ flex 3401 w/ 5 1/2 backing plate.
    Also what is the difference in the LC -6.5 CCS-Smart Pad w/ dimples vs the LC 6.5 Force Hybrid Foam Pad w/ hole?
    Lake Country 6.5 Inch CCS Pads 12 Pack - Your Choice! vs Lake Country Hybrid Power Finish 6.5 Inch Pads 6 Pack
    Thanks
    Rob
    I guess they dont make the 6.5 Hybrid Power Finish pad anymore, changed to the Force Hybrid?
    Lake Country Force Hybrid or Lake Country Hybrid Power Finish pads for FLEX 3401?-zzx-lake-country-6-5-inch-ccs-pads-12-pack-your-choice-15-gif-jpg
    Attached Thumbnails Attached Thumbnails Lake Country Force Hybrid or Lake Country Hybrid Power Finish pads for FLEX 3401?-zzx-jpg
  2. #22
    Oct 2016
    208
    Nobody has reported any issues with the center hole, either on the Hybrid Force, or any other pads that have a center hole. I am hoping to devise a centering tool that would take advantage of this and allow perfect centering of the pad by locating on the backing plate bolt and allowing center hole of the pad to slide down into a perfect position. I don't know if this is available, but if it is, I haven't heard of it.
    The Hybrid Force pads, as per Lake Country themselves, are designed for use with a forced rotation polisher. They are thicker, and from feel alone, appear to have denser foam (my speculation would be that this is due to the possibility of standing up to the greater heat generated by forced rotation polishers). They are also much thicker, which allows them to conform to body shapes/lines better; the forced rotation polishers, not having the stalling characteristics of free rotation polishers, are able to spin these thicker pads with ease.
    The CCS pads were designed for use with free rotation DAs. That doesn't mean that they can't be used with forced rotation polishers, they are just not optimized for this use. They may not have the same longevity with a forced rotation polisher that they would with a free rotation polisher.
  3. #23
    Apr 2014
    490
    Quote Originally Posted by txchevyz71 View Post
    Actually I have the lake country 4" backing plate now. is there really a reason to go to the 4 3/8"?
    If it were me, I would save my money and just use the 4" backing plate. Can't see where 3/8" is going to make much difference. It's only a 3/16" difference in radius, i.e. only 3/16" difference at the edge.
  4. #24
    Aug 2018
    103
    I cant wait to use them. On my new flex xc3401vrg, the TV hinges is when I got my flex, the handle was loose, the side bolts were sticking out like almost a quarter of an inch, so I tried to remove them to see maybe they were installed wrong but couldn't budge them finally got one off and tried to screw it back in but it only went so far like it was, I am currently trying to get some suggestions on what to do, I really dont want to send it back, since I'm about to do some polishing in a couple of days. Looking for any suggestions.
  5. #25
    Aug 2018
    103
    Sorry about the misprint TV, lol, its supposed to be "the hinges".
  6. #26
    Jul 2016
    3,328
    Anyone know where there are any 5" hybrid polishing pads available? I don't know why they discontinued them? 5" is the perfect size for some things and a good option to have. I know there are a few finishing and waxing pads around but I already have them. Just need the polishing.
  7. #27
    Oct 2016
    208
    Quote Originally Posted by fightnews View Post
    The 5” pads were discontinued in late 2015/early 20016. You may have a chance to find some at the vendors who used to sell them, like Autogeek, if they have any old stock left. That would be your best bet, short term.
    Other things to consider might be to use the current 5.5” Hybrid Force polishing pads with your Lake Country 4” backing plate (note that there will be less support at the pad outer edge with the Lake Country 4” backing plate vs. the Flex 4.33” backing plate), try to cut down the Hybrid Force Pads to 5” as has been previously posted, or just move over to the Flex 4.33” backing plate and start using 5.5” Hybrid Force polishing pads with an eye towards moving all your XC3401 pads to 5.5” pads as the 5” pads wear out. The last option seems to be the best, long term.
  1. Lake Country Hybrid Force Pads on Rupes Mille ?
    By TTQ B4U in forum RUPES BigFoot Oribital Polishers
    Last Post: 07-01-2018, 06:10 AM
  2. Lake Country Force Hybrid Foam Pads New & Improved!
    By Bryan@Autogeek in forum New Car Care Products
    Last Post: 02-06-2018, 08:48 AM
  3. Lake Country Force Hybrid Pads *New & Improved*
    By VISITOR in forum Wool & Foam Buffing Pads
    Last Post: 04-12-2017, 07:35 PM
  4. Giveaway! Lake Country Hybrid Power Finish Pads!
    Last Post: 05-19-2012, 11:39 AM
  5. NEW! Lake Country Hybrid Power Finish Pads!
    Last Post: 03-20-2012, 07:47 PM
Members who have read this thread: 10
» July 2020
